- clarion 2-DIN DVD MULTIMEDIA STATION WITH 7″ TOUCH PANEL CONTROL, USB AND BUILT-IN BLUETOOTH
Entertainment-intensive with intuitive interface and 2-DIN format
VX709A FEATURES
- DVD-Video/DVD±R/DVD±RW/CD/CD-R/RW/Video-CD ready
- Built-in Bluetooth® hands-free (HFP & OPP) and audio streaming (A2DP & AVRCP)
- MP3/WMA/AAC compatible with ID3-TAG display
- Official DivX® certified product
- Plays all versions of DivX video (including DivX 6) with standard playback of DivX media files
- 24FM, 16AM station presets
- Rear USB connector
- iPod direct control (optional CCA723 cable required for iPod video playback )
- AV input
- Dedicated rear vision camera RCA input
- Subwoofer volume control
- 3-band parametric equaliser
- 24-bit D/A converter
- MAGNA BASS EX dynamic bass enhancement
- Built-in High Pass Filter & Low Pass Filter
- Motorised sloping control panel with 7-inch QVGA colour LCD monitor
- 6-channel audio pre-out and 2-channel audio pre-out for 2-Zone
- 2-Zone entertainment: front and rear separate source control
- 4 × 50 Watt internal amplifier
- OEM steering wheel remote wired interface capability
- Built-in IR Eye (RCB198 remote included)
- 4 preset wallpaper design
LargeView
Motorised sloping control & DISC slot
The space-efficient design of this mechanism allows enjoyment of CD, and DVD, in a single unit that enables easy media exchange.
Function display screens for full system information
Clarion’s in-dash, 7-inch monitor is the source for all media and function information, allowing quick access to a host of features with a simple touch of the on-screen menu. The menu is laid out in an easy-to understand fashion by displaying all actions related to the selected media source.
Entertainment functions that accommodate the latest in digital media
USB direct connection and control of even the newest iPods
By connecting an iPod to the source unit’s USB input using the USB cable provided with your iPod, it will be possible to control the iPod. The same USB terminal can also be used to connect a USB memory device with digital music files stored on it.
* To connect an iPod, please use the USB cable included with your iPod.
* For video playback, optional CCA723 cable required.
* Please see our website for iPod models that can be connected.
* iPod ABC Search is not available.
With a Bluetooth compatible source unit, you can wirelessly connect your Bluetooth capable mobile phone to listen to calls through your car’s audio system. HFP/OPP/A2DP/AVRCP protocols are supported.
DivX® compatible
DivX is a common media language that delivers a pure digital experience. DivX enriched video files deliver superior video quality and enables storage of more information on a single disk. DivX compatibility in a main unit means that DivX encoded files burned using a PC can be viewed and enjoyed in your car, just like you’d be able to at home.
Clarion’s 2-Zone entertainment system divides the incar spatial environment into discrete front and rear zones. As a result, it is possible for the front and rear seat passengers to enjoy different entertainment sources without interfering with each other.
Advanced technologies to maximise the sound potential of your car
24-bit D/A converter for superb sound reproduction
The digital realm is made up of unnaturally square sound waves, as opposed to the smoothly undulating sound waves characteristic of the real-world environment. That is why Clarion’s 24-bit D/A (Digital-to-Analogue) converter over-samples the digital signal to recreate the natural nuances and expressions lost during the sound reproduction process
Built-in High Pass/Low Pass Filter
The internal High Pass and Low Pass Filters allow you to set the frequency range of the audio signal that’s output to each channel to best match the acoustic characteristics of the front and rear speakers and the subwoofer.
Digital Z-Enhancer to easily match the sound to your car’s acoustics
This function employs digital signal processing with three preset equalisation curves each adjustable to LOW, MID and HIGH. You can choose from 9 custom EQ curves tailored to specific speaker types.
MAGNA BASS EX for dynamic bass enhancement
Now, Clarion’s new MAGNA BASS EX boosts the bass by nearly 10 dB at even lower frequencies around 50 Hz -lower than that of ordinary loudness circuits at around 100 Hz, to provide extra low-frequency impact. It even automatically compensates the volume level to ensure well-balanced dynamic bass at any level.
The entire sound spectrum is separated into high, medium and low ranges. The level of each can be adjusted separately. Customise the sound to suit your taste and your car.
Superior connectivity for flexible expandability and upgradability
Equipped with 2 channels for Front (L/R), 2 channels for Rear (L/R), and 2 channels for Subwoofers, the full set of RCA line outputs allows upgrading to a full-scale AV system with plenty of support for future system expansions.
The source unit for unlimited possibilities
VX709A offers flexible connectivity with a wide variety of input and output devices, so you are assured of seamless audio and visual entertainment, and precise customisation to match your specific needs.
4 preset wallpaper designs
Background patterns of the audio & video sources can be customised to suit your taste or your car’s colour scheme.
DivX_S,5.gif649 bytes · Views: 169 -
MP3_ID3_TAG,2.gif471 bytes · Views: 141 -
USB_S,10.gif758 bytes · Views: 170 -
Touch_Panel,11.gif582 bytes · Views: 163 -
Digital_Z-Enhancer,5.gif488 bytes · Views: 163 -
Magna_Bass_EX,5.gif678 bytes · Views: 141 -
24bit_D_A_Converter,7.gif528 bytes · Views: 156 -
6ch_Output,3.gif370 bytes · Views: 153 -
