Cl7 cl8 cl9
Yo ... anyone who know the question below .. please advice
I got a friend bought a Honda Accord CL8, at first I dont know what is the CL8, because I only know there are CL7 and CL9 in the market.
Need some experts to sort the specs below:-
CL7 got 2 specs:
CL7 normal: K20A 155ps (Automatic) Engine same as Local Civic 2.0?
0-100km/h : sec?
CL7 EURO R: K20A 220ps (Manual)
0-100km/h: sec?
CL9 I am not very Sure either 1 spec or 2 specs:-
CL9 Type S: K24A 200ps (Automatic) same as Odyssey Absolute Model
0-100km/h: sec?
And the CL8
- Now i know about the CL8, it is 4WD model ( horsepower? ) K20A or K24A?
0-100km/h: sec?
Thanks!
CL7 20e
Displacement, cc1998
Engine model K20A
Max.power (Net), kw(PS)/rpm155 ps (114.00 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm19.2 kg*m (188.29 N*m) / 4500 rpm
Power density8.84
Engine typeWater cooling serial 4 cylinder DOHC
Engine informationI-VTEC horizontal ranging chaindrive
Fuel systemElectrically controlled gasoline
injection system (HONDA PGM-FI)
TurbochargerNo
Fuel typeUnleaded regular gasoline
LEV system (Low emission vehicle)Yes
Compression ratio9.8
Bore, mm86
Stroke, mm86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km7.2
CL7 euro R
Engine model K20A
Max.power (Net), kw(PS)/rpm220 ps (161.81 kw) / 8000 rpm
Max.torque(Net), N*m(kg*m)/rpm21.0 kg*m (205.94 N*m) / 6000 rpm
Power density6.32
Engine type Water cooling serial 4 cylinder DOHC
Engine informationHorizontal ranging chain drive
Fuel systemElectrically controlled gasoline injection system (HONDA PGM-FI)
TurbochargerNo
Fuel typeUnleaded premium gasoline
Compression ratio11.5
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.4
CL8 20el 4wd
Engine modelK20A
Max.power (Net), kw(PS)/rpm152 ps (111.80 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm19.0 kg*m (186.33 N*m) / 4500 rpm
Power density9.61
TurbochargerNo
Bore, mm86
Stroke, mm86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km7.4
CL9 24tl K24A
Displacement, cc2354
Engine modelK24A
Max.power (Net), kw(PS)/rpm200 ps (147.10 kw) / 6800 rpm
Max.torque(Net), N*m(kg*m)/rpm23.7 kg*m (232.42 N*m) / 4500 rpm
Power density7.15
TurbochargerNo
Compression ratio10.5
Bore, mm87
Stroke, mm99
Final gear ratio
Fuel consumption at 10-15 modes, l/100km8.3
CL7 got 2 specs:
CL7A : K20A 155ps (Automatic) Engine same as Local Civic 2.0
0-100km/h : 8.9sec
0-100km/h: 7.2sec
0-100km/h: 7.8sec
CL9 Type S: K24A 200ps (Manual 6 speeds)
0-100km/h: 7.5sec
And the CL8
- K20A 4WD model 155ps ( Same as CRV engine Spec)
0-100km/h: 12sec
