charade aura brake booster
viko5805
i need help here.....if i want to change my brake booster for charade aura g100.....
any other booster that i can change...???
i cant even do emergency brake....its very dangerous....
my fren say if i change the booster will be more better...
is that true...???
thanks............
Any leakage at the booster bro? I've experienced that before...I'm not sure whether other booster can fit in.....
no.....no leakage.....
so how....????ur booster got leakage lar..???
beside change booster...what else can i do..???
change rear brake to disc brake...????
thanks bro......
Is brake booster = brake pump ?
This thing right ?
no...no..no....
the booster at the back of the pump...
that 1 at the wall.....
https://www.zerotohundred.com/forums/attachments/67866
my fren told me this 1....
viko5805,
sorry i confuse btwn brake booster & pump, previously my brake pump kong not brake booster :") ...From what i read, the 'check valve' at the booster is function to allows air to be sucked out of the vacuum booster. If the engine is turned off, or if a leak forms in a vacuum hose, the check valve makes sure that air does not enter the vacuum booster...I think mybe got problem, maybe the hose leak...
just my 1 cents ..hehe
Oh, in that case, my old Aura is brake pump kong, the oil leak from the pump... So I guess different case, the earlier symptoms I got from this leak is spongy braking system, can keep stepping further and further in (even with the brake level max).
Changed to the Deto pump + booster, everything solved.
ok bro........
thanks......
i try......
btw.....if i want to change aura rear brake to disc brake....
what kind of disc brake can fit aura ....
cheerzzZZzzzz.........
g100s said:
u can use the aura 1.3 disk or the GTti(da turbo version)
Aura 1.3 tak da rear disk brake. Can use GTti or Detomaso disk brake, the later is easier to find in half cut.
I buy from half-cut, complete rear disk gtti + rear absober gtti for rm500.00.
i think gtti rear disk is hard to find, better look for detomaso rear disk.
ergh, i got detomaso front disc brake laa....extra set, never used before..half cut condition....its vantilated not like the original aura disc which is solid disc....
and the rear can use GTti or detomaso, doesnt matter, can fit...front for aura oni can fit GTti disc and the detomaso front disc oni can fit into espri or ascend.. =)
I asked a mech here in Penang and he said he had modify before Detomaso front disc to fit an Aura before, it works but in the long run got reliability problem like some odd noise coming out due to the modification. Either his material used is not good enough or the assembly work is shabby, but either way, if you really want, I believe a good workshop it should be able to fix.
