J jlxover Known Member Senior Member Feb 26, 2007 #22 JL Ceramic Coating :shades_smile: Sure. It help to reduce the exhaust surface temperature which means reduce engine compartment temperature. cheers.. flushafteruse said: so it can reduce the manifold temp?? Click to expand...
D Doink 3,000 RPM Senior Member Mar 1, 2007 #23 i think if u use stainless steel pipping it also helps to keep the temp inside the pipe... how much price for creamic coating???
J jlxover Known Member Senior Member Mar 1, 2007 #24 ceramic coating :shades_smile: the price is depend on what exhaust manifold that you want to coat... NA or Turbo manifold? cheers.. Doink said: i think if u use stainless steel pipping it also helps to keep the temp inside the pipe... how much price for creamic coating??? Click to expand...
