~cefiro A31 owners forum~
Originally posted by topui11+Feb 17 2005, 19:54 -->
QUOTE (topui11 @ Feb 17 2005, 19:54 )
Originally posted by gwsallen@Feb 15 2005, 21:01
--QuoteBegin-space_cowboy
@Feb 14 2005, 09:21
hie..
gong xi..gong xi nie....
what u do la bro cny...
cheers'
eat, sleep and pang sai :P
eat.. sleep.. pang sai... all lyzard king already. muakakakakakakaka
aih... damn bored ler. hehe
:P [/b][/quote]
dat is what balik kampung all about. surrounded by estate, padi field, farm and etc. so blending into the eco-system become ular sawa the best la... :P wanted to help out in estate, farm and so on need skill, one mistake may cause huge damage, unlike us in office got liquid paper. farm estate all living things u know, imagine u damage oil palm or rubber tree, how long do u think they will grow back? so the best is become ular sawa still :P
ey guys,
after a long search, had to settle for a putra. too bad, won't be joining the nissan drift gang for a few years maybe (3 years kua?)
sigh.
there goes my hopes of drifting.
anyway, thanks for the help guys.
Originally posted by whatdamn@Feb 18 2005, 13:00
ey guys,
sigh.
FF also can drift. wanna throw in four throttle in your coming 4G93? tsk tsk tsk :D
DRIFT! DRIFT! DRIFT! like this ---> ~
guys,
I newbie with A31
My car currently using standard rim. want to check whether this rim and tyres is suitable for A31. :huh:
Offset: +42. PCD: Dual PCD 100/114.3 - 8 HOLES. Comes with a Falken ZE512 205/40/17.
im selling my Ceffy, anyone interested? :D
go to the link:
http://zerotohundred.com/forums/index.php?act=ST&f=52&t=47124&st=0#entry769764
Originally posted by space_cowboy@Mar 3 2005, 22:55
uik...
why selling it off...the heat is around man....
btw, where all the mangkuk hayun arr....
cheers'
RB's too powerful.... kecut la... play kelisa better :D
muakakaka.. mangkuk ayun devious17... hahahhaa
weh.. how how? got jalan2 or not? hehehe...
anyway, been really bz ler nowadays. hailat ler... haih...
Originally posted by devious17@Mar 4 2005, 01:57
One mangkuk hayun reporting in .......amacam senduk? ada baik? hahahahhaa
hello mangkuk hayun #2...
mangkuk senduk #1 here...its been a while ur in here lah, where have u been...?Jalan2 cari makan or cari more mangkuk man....
how have u been lah.....
topui - ur hali cabut already arr...?how could that been...?tell me more....
cheers'
hhahahahhhahah......sup cicak anyone? hahahha
Me in EU at present, to engrosed with work. Open concept working environment so less chance to do my own stuff except after work.
hai guys can some one help me...
actually i bought my cefiro two week ago, and one of my friend advice me to change all the belt and also some other important parts. since then my car was run very smoothly. just two days ago it start white smoke ,when i check in workshop they told me better to change engine bcoz the cost of overhoul is equel to one half cut car, but now the problem is just two week ago i change my all belt including timing belt. wat should i do ..... it s better to repair it or change the engine . plzzzzzzzzzzzzzzzzz give me suggestion.
You mentioned that you changed all belts including the timing belt.
I assume that you would have changed the water pump. If yes it could be a faulty or leaking water pump.
White smoke is usually water burning, blue and black smoke is oil burning. So since the most recent change was the belts and assuming you did change the water pump, its best to check it out. Go back to the mechanic who did the change to confirm it...check your radiator and reservoir water level make sure it doesnt go dry and overheat the engine.
And yes it is probably more worth it to get a transplant done then an overhaul.
Just the r32 engine alone will cost around 1k +/-
r32 halfcut probably around 2.5k
Engine overhaul can cost anywhere between 800 to 1k....
cheers ;)
water burning? if the water gets into your combustion you wouldn't have any smoke of any kind.
White/blue is burning lub
grey/back too rich mixture
water? change engine.
