Z zulfadly Known Member Senior Member Feb 24, 2010 #1 hello guys... i wanna ask somehing about evo engine.. 1-if use 4g64 crankshaft with 87mm stroker piston,what cc can get? 2-if use 4g64 crankshaft with 86mm stroker piston,what cc can get? tq..
kroolada 3,000 RPM Senior Member Feb 24, 2010 #2 my basic formula when build engine.......hope can help u 0.0031414 x (s) x (b) x (b) 0.0031414 x 100 x 87 x 87 = 2378 cc
cipan_supercas 1,500 RPM Senior Member Feb 24, 2010 #3 volume of a cylinder = pi (3.14) x square of radius x stroke you're trying to find volume of the whole engine, therefore you have to multiply by 4 to the answer. That will give you the volume in cubic mm. divide by 1000 and you get the answer in cc.
