Carburetor engine difficult cold starting
RigerZ
I have a 1981 Datsun 120Y which very often has trouble starting in cold weather, especially after overnight rain. Even using the choke doesnt seem to work. I'm pretty sure the problem lies somewhere in the carburetor, but my dad suspects the ignition coil isnt making enough voltage for the spark plugs.
But then again I do notice my battery is significantly weaker in colder weather and the cranking isnt as strong. When I give it a jump start the engine would start almost all the time. I seem to understand that the weaker battery would cause the following (please correct me if mistaken):
- Slower cranking leading to weaker compression in the cylinders; air/fuel mixture doesnt burn properly
- Less voltage going to the ignition coil and finally to the spark plug; weaker spark doesnt ignite the air/fuel mixture
Anyone knows any other possible causes of this problem?
I was thinking the same whether my carb kancil is also because of this problem. Actually happens after replacing the spark plugs and the plug cables to borsch ones. :hmmmm:
i tot all old cars has problem during cold start, had a Toyota LE before gotta pump the accelerator when turning the ignition
Yours is still the old battery?
New bro. Changed to NMF battery. Just recall after changing the plug cables and spark plugs and also did the air valve on the same day. Only got such problem after that. Before that it was okay.
So not sure if the spark plugs is the wrong one given. Plug Cables are borsch.
Then is new battery mah! Not battery issue dy......:biggrin:
Could it be plug cables or spark plug problem? Cold start only problem. Always have to step on gas a bit to prevent it from dying off. Another way is crank until start. If die off, start again 2nd time then it will be okay. 2 way. But step on gas vibration not that bad.
Thats what the choke should be for, but on my car the choke doesnt help :(
Have you ever had the carb serviced? Could be dirty and choke not working?
---------- Post added at 07:49 AM ---------- 6 hour anti-bump limit - Previous post was at 07:46 AM ----------
Sound like fuel ratio is lean for cold start. Try the choke or like you say just step a bit on accelerator until stable. No two cars start the same way. Even my VR sometimes stable, sometimes chokes and cough, step of accelerator a while and then stable...hahahaha:biggrin:
Change battery, if it is done, check your carb, try to service it, den tune it...used to do tat to my tiara, running on carb...
Yup doing that every morning :laugh: Step on gas a bit and let it run gradually awhile. Then only jalan. After that the rest of the day should be fine unless I leave it till night time then got slight cold start problem. But is bearable.
How to tune? U mean adjust the choke?
Fong should have tuned it already, right?
didn't know adjusting the throttle (accelerator) cable can adjust idling, for my AT deer, adjusting it oni sets the gear changing mechanism to faster @ slower response.
Yup, but still have cold start issues :rofl: Cuz by the time i reach there no more cold start issues.
Tuning the carb is not for cold start issue. Is For normal driving.
Choke is for cold start but your very minimal so don't bother, just step a bit on accelerator....:biggrin:
---------- Post added at 09:17 PM ---------- 6 hour anti-bump limit - Previous post was at 09:14 PM ----------
maybe shud use tb cleaner to wash the throttle and see how. I saw a bit oily inside.
Meaning to say according to the article, car running too lean also not good it seems. Will try to adjust again
Worse case, open up and service the carb. Since most of the other parts have already been done, like your brake fluid nipple also jammed up already....
---------- Post added at 09:19 PM ---------- 6 hour anti-bump limit - Previous post was at 09:17 PM ----------
That one is when no adjustment screw. By pulling the cable tight already open up slightly the fuel feed to increase the idling....
Open up and clean? Can get your guidance ar? I only so far see the carb area that looks like throttle body flap. That part that I posted in whatsapp today. Izso said use carb cleaner to clean that part.
Ya so far only cold start vibrating. Other than that when driving, engine is consider smooth. Maybe can adjust to the best that can save more fuel? LOL!
Last time when it was vibrating more when driving, it saves more fuel. Now adjusted not much vibration but seems I can no longer hit 260km, now only 220-230km full tank LOL! Maybe max 240KM
in u'r case, the oni thing I can think of is, when idling u'r rpm is higher coz want to reduce the mounting vibration, when gear engage its rpm is lower but less engine vibration, so the more u'r car idles, the more fuel consumption. I know this coz the same wit my dear + my tachometer reading is like that when idle & engage gear
