car(wira) light very weak
iRON88
can someone help me with this? i just change my bulb n i don't think my battery is weak. does anybody know what could be da problem? isit the wiring or electrical problem? plz help i've been driving like a blind bat...
is yr headlamp original or imitation?
if ori, then try adjust the height of yr beam, u can see a level to adjust behind the headlamp.
if imitation, then u have to use screw driver to bend the desired height.....bit complicated.
Does your headlight brightness get affected when you on/off pedal? if so then try grounding wire, cheap and useful... it works for me.. : )
if your front headlamp is ok, try to install relay for your front bulb, if you go to spare part shop, ask for wiring relay for front lamp bulb... this should help to improve the bulb brightness...
yes try install relay....or check u lamp fuse
