Car swaying problem
m a v [3] r i c k
9,000 RPM
Hi sifus,
Need some advice here.
Few months back, my car a Proton Wira 1.6 has encountered swaying problem.
At times the steering would pull to the left and at times will be to the right even on a straight flat road (Kesas, NPE or Federal highway).
Even on straight road the steering always has to be corrected.
I've changed rims, 4pcs brand new tyres (PS3), all rear bushing (including trailing arm is brand new), alignment but things became worse!
Front lower arm (driver's side) changed to brand new Taiwanese but only lasted 6mths (ball joint loosened). Opted for a pair of used ones from chop shop but lasted only 3 days. Now it has got the "kluk" noise whenever I accelerate. Engine mounting has been changed.
I suspect the ball joint is dead again.
What I'm curious is, what could possibly kill a ball joint so fast?
Car is stock standard to the bone except for 15" sports rims.
Any input is very much appreciated!
Which side that swayed? Front or rear? If front try to check steering rack, rack end, tie rod end.
Yup, steering rack especially you mentioned sometimes left, sometime right.
Any free play on your steering when turning right and left?
Danz,
That's what my mechanic suggested also but I always thought if drive shaft is faulty then it will make the "klak klak klak" noise when making a u-turn? Mine got no sound at all. Drive shaft head (nearest to disk brake side) has been changed while trouble shooting this issue. Gearbox side checked by mechanic and he says its ok.
peeche,
Previously was the rear, hence change every single bush at the rear. Now I can't really feel if the rear is swaying as the front swaying is really bad. Don't dare to drive 120km/h even on straight highway. Tie rod has been changed too. Steering rack bush has been checked to see if the whole steering rack moves when car is stand still by turning steering. Steering rack doesn't move at all. Steering rack bush was also new. Where is rack end?
vr2turbo,
Surprisingly no free play at all. This is the headache part. Normally if there is free play then easier to troubleshoot.
Any idea if a faulty steering rack can kill a ball joint prematurely? Need to find out how come ball joint can koyak so fast.
Rack end is the shaft connected to the steering rack. The other end connects the tie rod end.
Jack the car up and try to move the front wheel left and right. No movement means rack end okay.
That was checked by mechanic...he even dismantled the wheels and disconnect the tie rod from the bracket and check the rack end if it has free play. Result is its fit and no free play. Big headache with this issue.
Could power steering pump somehow cause this issue?
I have nothing to contribute. You guys have covered everything.
That kind of unexpected swaying is usually toe-in/out issue. Probably a linkage or something is gone case. Heck it's possible even the absorber kong
Izso,
Exactly that feeling. Feels like 1 side of the front wheel is having "loose" toe setting. What other linkage to be checked apart from what bro vr2turbo and Danz has already mentioned?
steering rack bush?
try ask someone to shake the steering wheel while u check from the engine area see got free play or not.
mine persona got free play eventhough change new bush.:hmmmm:
m a v [3] r i c k;1064490484 said:
Izso,
Personally, I'd jack up the car and check everything starting from the rims, to the arms, to the ball joints and everything. Then have someone turn the steering left to right x 10 and you just monitor and look at how everything is moving.
The other thing I'd do is after jacking up the car, try to move your wheel left right left right and see if you have free play. If you do, your driveshaft or something along the lines is gone.
as well as worn steering rack to..must check for steering freeplay while car on ground and engine off...
He mentioned all that checked already from tie rod end, rack end, steering free play etc....
Normally if sometime left and sometime right is something to so with steering...
punk,
Steering rack bush is one of the first things I've changed since this issue started :(
Izso,
Will send my car to another mechanic to check. So far I've been to 3 alignment shops and 1 workshop to check on the fronts for free play and everyone said there's no free play. Even when I'm driving it, I don't feel any free play at all. The feeling is exactly like wheel toe setting is not right but somehow, I don't think going to 3 different shops to do alignment still couldn't solve it.
Hopefully by the time I get the car back everything will be alright.
pomen,
No free play :(
vr2turbo,
Every linkage has been changed :( It was solved once when changing the lower arms but only lasted for 6 months :(
Just for info, things I've changed within this 1 year are :-
- Steering rack bush
- Tie rod end
- 1 pair lower arms
- Both drive shaft head (nearer to disc brake side)
- Teflon anti roll bar satay bush
- All rear arm bushes
- New rear trailing arm
A friend of mine suggested that changing the front camber screw back to the stock ones. Could this be one of the issue?
If the camber wasn't tightened then maybe but you'd notice the camber difference very easily. And in all 3 alignment shops what did they adjust? Did you take note of what was out on the machine readings?
In all honesty I'd personally would rather test drive the car myself to understand what you mean then probably can diagnose better. Unfortunately I'm not in this weekend so if you can wait until next weekend maybe we could meetup and we could DIT.
Anything for a Wira. Hehehe.
Okay, another DIT / TT coming up....:driver:
All 3 shops also check the wheel for free play and all also said its OK. Yes I always look at the alignment machines reading but frankly I don't really trust the machines. If it is really accurate then they don't have to take the car out for testing and then adjust the toe based on their feelings right? :)
My front camber is -1.5 and rear is -1. Toe is 0 on all 4.
Next weekend I may not be around. It's a good idea to meet up! Hehe who is in? What is DIT btw?
TT will be good. Last I attended ZTH TT was way back in 2001-2003.
DIT = do it together.
DIY = Do it yourself
Why are you running on so much camber la? You'll get uneven wear for the front la. I'm beginning to suspect your tyres is the culprit
