car jerking/timing drop during cornering
ae101rulez
guys, my carby engine have a irritating problem...the engine timing drops which causes the car to jerk when enter cornering especially if you tekan minyak in corners...its like a feeling of lack of petrol lidat...btw, my car is LE EE80........
when u whack corner only? straight road is ok?
there is not enuf fuel enter carb when u whack corner for sure....
float problem at ur carburetor...
fuel filter clogged...
check fuel lines...
check fuel level in ur fuel tank...
mostly due to insufficient fuel supply... check everythng that concerns fuel delivery....
If u want to replace a carb better change engine...
Carb is very expensive...if u can get chop shop also depends on your luck... new one huh huh..can kill you man...
ya, check fuel lines first...
what carb u using??... certain carb can repair the float... and, carb doesnt cost a bomb la... it is cheaper than an engine...
To all the sifu,
My wife's car is facing the same problem but it only happens during the morning. Have to warm up about 5 min if not the car like no power, tekan minyak oso the car like no feel. I've already changed the plugs, plug cable and oso still like tat. Any suggestion ?
Tks.
Ps. it's a 1.3 proton iswara aeroback - 8 yr old.
