Car Auto Accessories & Air-cond Part & Service
sgwangacc
Car Air Cond Part Fix & Service
Seat Cover Installation
Sound Proofing In Progress
Tinted Film Installation
Welcome to contact us for any related inquiry / appointment
Hi, the air cond blower of my kembara seems like quite weak. Also, I might wanna service my A/C system. Just wondering how much would it cost to fix the blower and service the A/C, ya ? Kindly provide the best price for me. :)
Thanks for sending us inquiry.
Sounds like your a/c blower motor is not working well.
Pm has done. Look forward to hear from you soon!
Air-cond Compressor Proton Saga BLM
Replacing the old compressor to the new one
Installing the air conditioner compressor onto the Saga BLM
Problem: Air-cond is totally not cold when engine starts
Solution: Replacing an air-cond compressor on a Peugeot 308
Full Air-cond Service & Replace Cooling Coil on Toyota Camry
Stage 1: Disassembling the Dashboard & Taking Out the Cooling Coil Unit
Stage 2: Dismantling the old Cooling Coil Unit & Checking for Leakage & Replace with a New Cooling Coil
Stage 3: Assembling back the Cooling Coil Unit & Dashboard
~ Cabin coldness is back to life. Enjoy! ~
Full Air Cond Service & Replacing Cooling Coil on Toyota Alphard
Dismantle the entire dashboard
Dismantle the whole set of blower & cooling coil
Taking out blower, motor & cooling coil to clean & test leakage
Cooling coil leakage found!
Exchange a new Cooling Coil & Expansion Valve
Assemble the blower, motor & cooling coil back to dashboard
At the same time, dismantle the front bumper to have the Air Cond Condenser get flushing service & Screw the hoses back to its place
Starts to assemble back the dashboard frames & other components
Front bumper & Dashboard is recovered!
CONTACT / VISIT UShttp://www.sgwangacc.com.my/contacts-sgwang for servicing your Toyota Alphard.
Product: Turn Signal Bulb
Light Color: 2 Tones LED (YELLOW for Signal + WHITE for Daytime Running Light)
LED Amount: Total 20 Diodes (10 Diodes for Signal + 10 Diodes for Daytime Running Light)
Beam Pattern: 360 Degree
Operating Voltage: ~12 V
=CLICK ME TO VIEW YOUTUBE HOW IT WORKS=https://www.youtube.com/watch?v=AsK-m8_wrMw
Features:
- Replacing original Turn Signal Bulb (type 1141 OR T20).
- Designed to fit original factory bulb sockets for easy installation.
- When normal driving, it works as white color Daytime Running Light. When switching turn signal (left / right), white color LED will off and yellow color LED will flash.
- Aluminium housings provide better heat dissipation and weatherproof. The result is long life and no maintenance work.
- Glass lens provide better lights transparency and abrasion resistance.
- LED bulb illuminate faster & produce less heat, compare with traditional halogen bulb.
Remarks:
- Sold in Pairs
- Nationwide delivery ready
- Contact us for other types of LED bulbs (880, 893, H1, H3, H7, H11, 9003, 9004, 9005, 9006, 9007, 9008)
- Professional installation in our outlet is available
!! CONTACT US NOW !!http://sgwangacc.com.my/contacts-sgwang We provide professional installation.
