Can my kancil install intercooler?
Joeker
Walking Dead
I stumbled on this picture of a Kancil with intercooler.
The owner of this kancil say he install the intercooler on his 850 Kancil carburator (izzit possible?)
He say after adding this intercooler, his car can rev faster and can rev until 11,000RPM (he using 15K RPM Tachometer), fuel consumption decrease by 30% and 40% more torque.
rev till 11k he must be BS you. or watched too much initial D la. stock engine parts simply can't stand till 7k+ rpm as i read b4 somewhere. you need forged pistons and stuff.
from my view of the first pic the right hand side of the intercooler seems to be a 'digitally' touched black area.....most probably it's a hoax. there's no way to install that IC to the top of the engine, there's no space, see the thickness of the IC.(unless he drilled a hole on the bonnet la.)
and look around, how the heck the guy attached the IC to stay put? there's simpy no way on that engine bay.
I think its black hose but seriously, is it possible?
Originally posted by Joeker+Feb 17 2005, 23:23 -->
QUOTE (Joeker @ Feb 17 2005, 23:23 )
--QuoteBegin-DimDimer
@Feb 17 2005, 23:02
I think its black hose but seriously, is it possible? [/b][/quote]
NO....you can't and it's not a black hose on the right side, the pixels and ambience lighting on the 'hose' is all incorrect.
tell this to any motorheads their a$$ will come off due to so much of laughter. i think it's better you keep to yourself.
secara teknikal IMPOSSIBLE.
the engine is not getting much air into the chamber due to the intercooler fins restriction. with turbo, air is pushed, but in this scenario it's sucking. the main point here is the intercooler fins are giving hell lots of air restriction and the engine air sucking power is not strong enuff. it's like drinking water through a crumpled straw.
and 40% torque increase and 30% lower f/c with this mod is a dream. the claimed power increase is equivalent to a turbo system and more power = more fuel consumption, simple as that.
11k rpm.......explained earlier why it's a BS.
Originally posted by CcL@Feb 17 2005, 23:21
lol
a technical reply for a joeker post
/sarcasm
he is just the best in unconvetional ,unimaginable ,unproven ,untested and seriously raw power
everyone ought to do a search on his name for surbo ...
the intercooler doesnt seem to have a need to be there.
true what DimDimer said,your engine can't handle that kind of revving.unless you do the required mods.
From previous discussion, we know that the rev of tha engine can sustain until that limit.
beside that , let think what is actually the function of intercooler,The air is compressed by the 'siput' then fed into inter"cooler". The name stated that to reduce the temperature of that compressed air.
I think its better to place your intake filter direct from outside the bonnet (much cooler air) compare to take from inside then go to intercooler then to your filter.
Hmm... do i correct ?.. i'm just beginer. hope all 'sifu' can give lesson. TQ
:ph34r:
yalor..a typical Joeker post..kekeke ..1st SURBO..now this...hehehehe..
GOOD ONE Joeker..... salute you..!!!!! :D
