this is the spec
Clarion CD Player(DB 256)
Kickers Impulse I5.2 component speakers
America Sound CEX-800 Elec Crossover 3way
America Sound 2Channel Amp CS 50.2(For Mid)
America Sound 2Channel Amp VL-800H(For Sub Woofer)
Tomahawk 12" woofer(2pcs) c/w
Open Vented BoX
If you want to use it on the power supply to amp to get louder bass then it is not worth buying it.
If you want to use it on the audio signal line then it will function as high-pass filter. Good if you want high frequencies only going to your speakers and you do not have passive/active crossovers to do that job.
if your lights dim when the sub bass kicks in, then it can help a bit, but more importantly it doesnt cure your alternator & battery charging problem. if your a bass kaki and play loud a lot, then i guess theres no harm in adding it..
thanks to you all for the explaination lol
but i heard that izzit that if put the capacitor besides the amp for the sub
it will make the bass more harder
and also it will help the light not much blinking ah
cause everytime my sub(boom)
the light starts blinking
izzit the capacitor will help
depends on the amp power, usually 1F capacitor for 1000W of amp, so if the total of your amps are below 1000W then u can connect the amps to one capacitor, if more, then u have to get more than one capacitor...
not really. for loud bass, sub is what plays the most, and that is the one that requires the most power, since the subs are the largest speaker in the system, so cap for sub amp is the one that can make any difference. unless youre charging system is bad, u wont get any difference if use cap for component amp...
Why so susah? Offer him cheap cheaplah. That thing will solve your bling bling lights. Ooops, the cost is higher than both the amps + HU+ speakers:shcokedcamo:
