camshaft-which one is better?
eddie_vtec
Hi all...
which one is better...cam b16b or b18cr?
some one said no difference..some one said a little big difference...
pls comment.....
If you don't know about camshaft degreeing.. those two cams will not make much difference.
Depends on your engine setup.. one of them might be better than the other.
eddie, sometimes you'll get more just by changing the cams instead of going for bigger cc....
only different 3 degree... nothing much different i think...
its only bcoz ctr got 'higher' duration then ppl more towards it...
n i believe if ctr cam only different 1 degree oso ppl will go for it.
or maybe anyone here can explain in details what will that 3 degree give an advantage?
both aso very the good cams lah.....very the stim one.....
yeah b16b might be better...but considering the price different about rm200-300....better settle for b18cr instead....go eddie go!
aduhai sifus, are there any aftermkt cams tailored to engage at 5000rpm like
small v cams but offers that crack wilder profile/ lift that we r all looking 4?
Exhuast cam are the same....
Intake cam only different by a few degrees... hardly noticeable on the road....
for manual or oto aplikesyen ni bro ?:_:
hattech-v said:
yeah..... go eddie go... ale ale ale... hahahhaha
u advise la eddie...use togeder with titanium retainer n JUN valve spring...rev kaw2....very the syiok wan.....he sure addicted to it later lah :_:
carnage said:
aduhhh bisaaaaaanyaaaa.... huaaaaaa....huaaaaa.....
hik..hik...sori bro...i thot u oredi convet manual tranny...pardong my ingnorang (slang tganu plak..hehehe..) :_:
