Campro Turbo Kit
Campro Turbo Kit
Shazerone
CAMPRO TURBO KIT- FOR CAMPRO, CAMPRO IAFM AND CAMPRO CPS
Customed Turbo Manifold (banana)
Actuator valve
Manifold gaskets
Downpipe gaskets
Steel Braided Lubricant Hose
Customed return valve to oil pan and return hose and clamps
Customed Intercooler
Customed Intercooler pipings and fittingsl
Rubber hoses and clamps various sizes
Lots n lotsa more small bits e.g. nuts & bolts, lock pin, & fixtures
* Price inclusive of installation of above items in the kit. Our Kits are already R&D to get the minimal lag (very good response) and power stays until rev cut (example : you use TD04 gud response and minimal lag 2k rpm already boost starts but after 5k rpm power drop, use TD05 power lag 4k rpm only full boost altho power continue until rev cut)
Let the profesional handle the settings and the dimensions for this campro turbo kit.. We tested all sorts of sizes and this is the best balance in terms of power, reliability and durablity.
** Kit comes with warranty on engine reliability
*** Kit comes with atleast 170 hp of campro power!! :driver:
bro, although i not interst on BOT campro but ur kit is awesome:top::top::top:!!!!! free bump for u!!
hehehe, thank u so much for the support bro!! Yeah, this is an awesome item which can get u 170-180whp on Campro engines! And reliable too! All already been RnD!
---------- Post added at 12:24 AM ---------- 6 hour anti-bump limit - Previous post was at 12:20 AM ----------
170 hp with this BOT? :smile:
Yes bro, 170-180whp guaranteed :top::top::top:
---------- Post added at 12:28 AM ---------- 6 hour anti-bump limit - Previous post was at 12:24 AM ----------
bro...it that an Exora BOT? with FMIC?
Yes bro, and it produced 150whp... Impressive for an Exora... The car really pulls nicely now, not underpowered anymore :driver:
Hi,
The price include turbo or not? TD04 or TD05?
Is it suitable for exora auto? Do you have engine and transmission oil cooler?
How much if i only buy the kit with no installation?
TQ
hi bro. where is your location? base on your phone number i guess its at KL/PJ area.
How many days to get the thing done? i stay in JB, just bought a Neo (non-CPS), still under warranty.
i'm a fans of Turbo and i already planned to get a BOT after the warranty or maybe abit early as long as the car run smooth (no need go back complain anymore).
So i need your location and how long you need as well.
"Kit comes with warranty on engine reliability" means guaranty no damage on engine and your kit?
170hp for installing only the BOT, how bout if i change the computer chip and the air inlet??
will it be more?
thanks for take time to reply me. :love:
Hi,
TQ
Yes bro of course include the turbo as well... depends on ur power band, we would then determine which turbo to use, but its between those two..
It is very suitable for Exora auto.. Its better to install with us, then only we can guarantee our product
---------- Post added at 11:55 PM ---------- 6 hour anti-bump limit - Previous post was at 11:51 PM ----------
will it be more?
Hi bro, yeap im in KL/PJ area..
Owh ic ic, thats a good car for BOT bro, with good power and good handling of the Neo..
Yes, kit comes with warranty on engine reliability, in fact we have a Gen2 cps installed the turbo kit just 2 days after getting the car brand new.. Well, usually installation and everything takes about a week depending on how many cars are in the workshop.. but its about that period of time..
Well, this turbo kit is with a management system, so once u install, then u would need a piggyback management system to support it, after tuning u can achieve 170-180whp.. :driver:
---------- Post added at 11:57 PM ---------- 6 hour anti-bump limit - Previous post was at 11:55 PM ----------
xenon's or other independent party?
Im selling on behalf of Xenon bro as he is one of my good friend, so you would know his product has been RnD and reliable :proud:
bro need advice. own a neo (non CPS) wanna but but scared car will be undriveable everyday. can advise? pls PM
BUMP! Kepishhh kepishhh.. :driver:
---------- Post added at 01:15 AM ---------- 6 hour anti-bump limit - Previous post was at 01:12 AM ----------
Hi bro, thanks for ur interests...
hahaha... Bro it is definitely for everyday drive bro, almost all of our customers use they're car on a daily basis.. For optimum power and everyday drive convenience and durability, Stage 1 is just enough, as u have 170-180whp while maintaining good fuel consumption and comfort too... :proud:
Hi kk9972..
The price i quoted here is of course without management. But as u know, u would have to buy and install the management system at a different cost. The management system that we recommend for u to use would be either Haltech Interceptor or E-Manage. Both are piggyback ECUs
btw..i hav one question..
if i install this turbo kit on cps neo vs. non-cps neo...mesti ade sikit difference in hp kan?kalau assuming everything else is the same la..i'll assume the cps neo will hav a slight advantage in hp later on, kan?thnx in advance..
