jaspersoong
- The air pump exerts wide ranges of use for all 12V automobile tyre, such as tyre of 4x4 off-road vehicle, Pickup, microbus, truck below 2T and limousine. Big air supply and inflate soon!
- It also can be used to inflate the motorcycle, bicycle, balls, rubber dinghy, airbed and inflatable toy, etc.
- It is good for the emergent needs that you are on highway and countryside road or rush to the office in the morning while the tyre has a low pressure.
- The appropriate tyre pressure not only save gas but also ensure the safety of driving.
The Way of Use :
- Plug power cord into cigarette lighter receptacle of vehicle.
- Start up the engine and turn on the switch.
- Push connector of the compressor toward the valve of tyre.
- The gauge will indicate the pressure of the tyre. When the gauge indicate appropriate tyre pressure, usually 28-35PSI, stop engine, unplug power cord and remove the connector from valve.
The Way of Use :
