bucket seat brackets
leynye yamin
Hi, i found a pair of Subaru impreza stock semi bucket seats, thinking of fitting them in my kenari. After measuring, the impreza seat original bracket is more less same as kenari bracket. just minor difference. Question is, must i use weiding to even out the difference, or i could just use thick metal plates cut fit to size and use nuts and bolts instead of welding? Thx!! i thinking of Diy install. if using nuts and bolts just fine i could just proceed install myself.
actually u just need to ensure the bolt holes are the same then u could bolt the seats onto the bracket,
if not get the bracket drilled. welding not neccessary.
please take care when drilling the bracket, make sure the it will not bend or break easily or else you'll have an ejection seat during an accident.
why not go to a shop and do it?.. they might have ready-made brackets.
