Brembo Max Disc Rotor
alan2011
2,000 RPM
Dear All,
We have supply for the following brake rotors upgrade/replacements for various car application.
Brembo Max:
Brembo MAX provides improved braking performance under all pressure and speed conditions tested in the laboratory and on the road. It also ensures greater safety in wet road conditions.
Genuine Brembo Max Disc Rotor for sell , Performance disc Rotor for excellent barking improve
1. Made form High Carbon Cast Iron .
2. Slotted Disc Rotor for Execellent colling effect
3. Better damping factor , these cast irons can reduce noises and vibration
4. Beware of immitation product
• Maximum performance on wet roads
Asymmetrical outward-facing grooves help disperse the water
• Maximum control of wear
One of the grooves acts as a wear indicator
• Maximum resistance to corrosion
The parts subject to corrosion are finished with a protective coat of paint
• Maximum response
The coefficient of friction is higher than with normal discs
• Maximum safety in all situations
The grooves rapidly expel gases and constantly renew the friction material
Model available for :
Mitsubishi / Proton
Daihatsu / Perodua
Nissan, Honda , Toyota, BMW, Mer E46, Accord , Civic, Perdana , Waja / Volvo S40 , Wira / Satria , Sentra, Galant VR4, E34, E39, E32, E36, W210 E-class etc
Serious Buyer Pls contact me 012-2791705
KL dealer
Prices for various models- do contact me if models not listed.
Chevrolet Aveo front rm430
Bmw 318 e36 front rm490
Honda Civic Eg/ej/ek sohc front rm430
Honda Civic eg6/9, Ek4, ES dohc rm490
Mitsubishi GSR pcd 114.3 front rm490
Mitsubishi Lancer Cs3 front rm490
Peugeot 206 1.4 front rm430
Proton waja 1.6 rm490
Proton wira 1.5 rm490
Bro,
I am using a B16AVTEC disc. If I am not miskaten, it should be states as EG DOCH RM490. Am I right?
If yes, the diameter of the disc is same as mine? Do you provide installation?
hey, i have a civic eg...but im not sure which brakes im using...
its either the eg6 brakes or a 1994 dc2 brakes
i only need the front pair and the size of them are 262 in 4x100....please advice
also the price for standard brembo rotors in that size above
and the price for brembo max in that size as well...
thanks
