braking system prob (satria 1.3)
cik_yat
anybody knows???
foot brake pedal suddenly feel loose (kosong) and need to pump once to brake.. usually happen while driving and sometimes while stop at trafic light.. i heard this prob already and common for early model of iswara and wira..
wut is da main prob?? how to solve??
everything already service last year on oct.. new oil n pump.. but i heard dis is common for early model of iswara n wira..
is it feel like sponge? maybe your brake fluid still got air inside..u might go service center to release the air or else change into aftermarket brake pad such as Endless brand.. hehe
problem solved.. no air, no cable prob, no drum broken..
master pump problem.. seals already expire.. if stupid pomen, they ask to change da master pump.. only solve by changing da seals, repair kit for master pump.. cost for me only 20bucks..
change servo not solve da prob.. servo 1part, master pump is 1part.. if change servo means, ur jamban got stuck but u repair ur sinki... how?
if servo prob, ur car got jerk n seem like engine want to die when brake..
Normally is master pump pro,leaking or pump seal pro,can try to change master pump seal 1st,if still not ok suggest to change servo brake pump double layers,more powerful breaking.no need to spend money to get brand new master pump.
