will installing steel braided brake hose increase braking performance?
yes.... braided brake hose will increase braking performance.... in a sense that no more sluggish brakes.... they wont help the brakes to grip more.... but it helps in distributing the force evenly....:regular_smile:weikhee86 said:will installing steel braided brake hose increase braking performance? what type of brake pad is good and yet does not cost too expensive? i'm using a proton
TermiziYeoh said:Ferrodo brake pads are better than OEM ones.And Bosch power plus & Akebono too.Definitely if budget allowed u'd go for Endless or Project MU rite.And yes steel braided hoses will help.Transfering all the braking force thru the hose.
what about GoodRich??... which is better??...Fluffy said:for braided hoses...ProRS is getting lotsa popularity.
most pads will not harm the disc unless you use a racing pad. so unless your disc is already near or below the minimum thickness allowed, there is no need to change it. unless ofcourse you double you're engine's power and the disc cannot get enough cooling between stops XD.weikhee86 said:i heard frm my mech..he said if want to change brake pads better change the disc as well cos he said the disc might not tahan the new brake pads..is it true? what if i get the type that does not wear easily? will harm the brake disc rite? plz enlighten me
