brakes shaking
mie4385
hi bros...
need some help here...last week just change to 15 inch rim from standard 14 inch...the problem is the whenever I brake from speeds of 60km/h or above...my brakes become shaky mcm tayar tak cukup angin ...my padel pun shaking like hell...apa cerita hah?
i ask a few workshop and they say either 2;
1) put a spacer con in the middle of the sportrim hole (but must custom made coz the gap is sooo thinnn)
2) change the tyres (currently on sime tyres)
fyi...this did happen with my standard 14s...only happens when change to 15s...so got anyone exp. this?
so kasi tolong sini apa mcm mau buat....
when i was using my standard 14s...this problem doesnt occur...since using the rims i'm having this problem...my disc checked oledi...still ok...
Previously i got this problem with my wira...i change the wheel to 15" rim and then whenever i brake from the speeds of 90km/h the brake shaking...So i went to my workshop and guess what...?? they ask me to put spacer con...then problem settle...no more shaking...this is came from my experience..hope it'll help u....
muhahahhaa....problem solved oledi...and yes i have to put a con spacer...here's a before and after pic...thanx for those who responsed...:)
i got for RM 20 for 1 pcs...but I try it out 2 pcs first for the front wheels...improvements instantly....planning to install for the back wheels also...pm me for the location and contact no....
hmmm but think no same rim hv not same size larr?? rite???
i jack up my car n run tyre look damn jerk lahhh...but when driving is ok...is it normal???
yeah my car also like that,when running is ok but when breaking its shaking...as if the brake padel is kicking me back...hahhaha
dude! i think i'm having the same problem as u. when i brake also i can feel the rear brake shaking. some of my frens said it's bearing problem but some said brake problem! even go through bump also can hear the metal sound sounds like 'king kiang kong' lol.
mie4385 said:
hi bros...
U sure it's not coz of your ABS kicking in or your brake discs warped?
Anyway don't install spacers on FF cars unless you know what you are doing. Spacers decreases your rim's offset. For an FF car you need positive offset. Placing spacers might place the load on your suspension at a wrong angle and wear out parts much faster.
spacer con
Hi,
From your pix, b4 and after, I couldn't really picture in my mind the spacer in itself. I just saw before, no yellow color. After install, yellow color from the center hub cap.
Could you PM me the location and phone number to get this spacer con. I need for my rear wheels.
By the way, what metal is it made of? Aluminium? Currently I have a spacer for my rear wheels but due to its aluminium material, the spacer gave way and now my rear wheel balancing is out. Thus shaking occurs.
Thanks!
bro...if oledi solved my problem...i'm using the spacer cone for the center hole...not the normal big rim spacers...fyi..my car onli iswara dun hv ABS :biggrin:
hey gusy im having the same problem here..whenever brake steering shaking..was quoted for RM120 for 4 cons..but not yet installed la..does it really help much..?
As according to the tyre shop boss..most sport rims might have this problem..how true is this statement..?any1 mind enlighten..thanx :)
most oem rims have this problem i.e. original rims from another car....spacers are also the culprit for this problem...anyway,check with friends or ur friendly regular foreman...there might be other problem that causes ur steering to shake....or u might just try out the front first...see whether the problem decrease or not...if not kasi tiaw kaw-kaw the tauke....good luck
me also have this problem... my car Kancil.. standard rim.. berfore this they told me brake pad.. but change it, still problem... mm
