Brakes Problem
Agl
Using the Mitsubishi GSR disc brake(rotor n the caliper-pcd114.3) can suit 1.3 wira?? Will it be better than the original brake?
pcd 114
Hi,
If you meaning pcd 114 gsr brakes fitting into standard wira car no prob. If pcd 114 hub fit standard wira rim then got problem. U need pcd 114 rims then.
btw how much u bought your gsr brakes (did it come rotor, caliper and knuckle?)
hope this helps
140dB
yup 2gether wit rotor n caliper, u mean if my rims still standard one cannot fix, then how bout 15"rims?
Price dunno, coz fren gave me one :)Juz no idea where to find a good place to change it.
minimum rim size for gsr front brakes is 14 inch.. the caliper size/rotor
are just the same with 1.6/1.8 protons except slightly bigger brake piston
change the pcd 2 100...
if ur fren giv u the knuckle also even better...use em...coz next time wann buy rim in chop shop...most of japan rim is 114.3
