Brake Oil Service
Hi all,
Just sharing.......
If Brake fluid is dirty it will spoilt the oil seal and gasket.
Is better every 20,000km changing. Low cost can save more problem.
Checking every 1month see any shortage at brake oil tank. ( If short that mean hose is leaking already)
if hose is leaking....ur fluid will gone in a very quick time.....wont takes a month...
brake fluid will be less when ur discbrake pad become less mostly....if u notice ur brake hose no leaking but the fluid inside is very less, check ur disc brake pad..most probably gotta replace oledi....
and after put in a new discbrake pad, u will notice ur brake fluid will be going up oledi....
correct me if im wrong
my2cent
