brake hose
kayy
Hi
Now im using std levin ae111 2 pot plus custom disk for the front and std levin ae101 plus disk for the rear in my ae101
1.Is the rubber brake hose im using now the same as the std ae101 (front disk/rear drum assembly)..cause im not sure wheter it changed or reuse the old brake hose setting
2.Is the hose length,braket settings,clips same between the 2?
3.if let say the setting between the 2 the same, then it is safe to say that if i buy off the shelf braided hoses meant for ae101 ,it will fit directly w/o any mod rite?
4.if anybody with similar setting have upgraded to braided hose..pls share :)
thanks
oo...so meaning the normal rubber setting and braided setting for MY ae101/111 and Levin ae101/111 is the same la eh ? :)
p/s..haa..duk keramat...taman keramat :)...duk keramat gak ke?
