Boost Tee Source
My MBC is tapped onto one of the vacuum pipes around the turbo area. As for source of boost meter, I tap it between the intake manifold and fuel rail.
my boost Tee just serve a purpose as wastegate delay (the ballbearing-spring loaded port inside)
because if i leak air (to increase boost) using the boost Tee...straight away i'll get boost cut :rofl:
plus...i'm using adjustable spring external wastegate....so just adjust boost direct at wastegate spring preload :biggrin: :driver: better boost control this way (because already delete electronic boost solenoid)
