Boost Off with fire
Legend Speedy
1,500 RPM
can any sifu tell me tat y a car can boost off wif fire????
izit only mod wif turbo den only can hav boost off fire?????
or without turbo oso can????
thankssss alot..... :)
2 option:
1st option is u modi ur car engine, enough to produce the fire coming out from ur bc ekzos.
2nd option is u install a device at the bc of the ekzos. its call the dragonfire. but that will harm ur engine...
by the way, wat car u driving?
also can be because since the car is turbo maybe the owner has tuned the car to run rich so wen boost in the car will not lean out and therefore safer 4 engine so... if the car is runnign rich there will still be unburnt petrol in the exhuast and the heat will cause the unburnt petrol to ignite thus creating a flame
Depends on whether you want natural backfiring or gadgetry ones... A simple rev limiter will allow you to backfire when you hit the rev limit.
For natural ones ah, easy la since you got turbo. Run on a richer setting + vent-off BOV (to confuse the air intake sensor), if necessary retard ignition timing then maybe can liao. Or if youre crazy enough go get an engine management and ask the tuner to install anti-lag... your exhaust can flame like crazy.
BTW, nice wei GTi GSR.
my car tuning lari oredi...now everytime change gear can hear POP....and im driving NA....cibet petrol damn exp. summore car running rich...aihh
do u all seen 2 fast 2 furious???
how bout if i wan 2 mod until like de skyline mode..
juz like startin of de race keep on cumin out wif flame????
if can den 'song' lo....
n how do i spend 4???
n where can i get mod if it????
thankssss......
Legend,
Its using a gadget called Fire Dragon or Fire Star or somthing like that to make the flames.
But before you got out and buy it, ask yourself this question.
Do you want to be Fast? or do you want to be Furious?
put aftermarket ecu such as haltech , motec , autech , microtech and etc ,
can preset the engine to throw flame when releasing the throttle ,
setup the fuel when vacuum to higher level ... so extra fuel or waste fuel will end up at te exhaust and make flame .....
YES!! And make sure to buy them from KSP Racing!! :p
Joeker said:
Legend,
brother... fire dragon not good for engine in long run le..
coolblue, do you need turbo engine to the setup you post up there?
aiya, very dangerous la this fire dragon in long run.muffler need to refibre back and scared bumper also cair woo. i know la u all want to be like jinyi/kyouichi in initial d but this one aint misfiring system like in da cartoon la dude.hehe
