Boost drop problem , pls advise .
ce9a_evo
Hi guys ... I'm running stock evo 6 engine with Greedy Profec-B specII boost controller .
I set my low boost with +30% on de controller , de boost runs up to 1bar and den drop back to 0.8bar .
What can i do to keep de boost maintain at 1 bar ? Do i need to set de gain % on my controller instead to maintain de boost ?
tq.
Hello ce9a_evo,
it would be best if you channel this Q to Mitsubishi Lancer Owner Club (MLOC) thread.
u might get some info/guide from the EVO owner there.
regards,
pangyau
tq.
add the gain so the boost stays consistent
play with the start gain and gain to get a consistent boost..
set the start gain a bit lower than your target boost and set the gain to get a good boost response. Gain setting will affect you boost spike...
what is de purpose of setting start gain lower than my target boost?
If i set my gain higer , izit boost will come earlier and might cause boost spike?
