Boost controller - Any recommendations?
boost spike issue can be just a mere small leak somewhere along the boost line.... check whether there is any vacuum lines which accidently installed wrongly.
i suggest avcr.not the easiest to set up but once you get it right it works a charm.boost settings can be set and fine tuned thru every gear .
i am using blitz sbc icolour.not the best out there but pretty accurate and the dual solenoid is very reliable.
yup,true olso u can try the tulang ikan, becouse my friend boost 3bar olso use tulang ikan,u can try it ......:proud::proud::proud:
3 bar with tulang ikan ?????? wow this is damn high bro ...what car ur friend using with what turbo n what is his whp
Bump: if ur using managment do u still need a boost controlled ???? or can be set from the managment the boost level?????
