Bolt on turbo kit
Bolt on turbo kit
Bro lilvee :
there is no problem to install this kit to your car , is depend you want it or not.... :D :D in this world nothing is impossible....haha (very lcly) just jocking.
kiyoko_88 :
bro is depend you want high rev and high boost or high torque at low rpm , if you want to gain high torque at low rpm , then you need to have a smaller turbo , if you want to high boost and gain high g-force , then bigger turbo suit you. the most importance is you ecu..
blur civic :
bro very sorry i dunno how to draw a map from my computer , or you can call them or call me directly and we will guide you to the place ... my phone : 012-3963348 or Drager Racing : 03-62754508.
Act, i'm in a quest to boost my d16. I got my e-manage oledi. The rest, need to survey la..
Bro.. do u mind to list down ur kit that u had installed there?
1. Turbine (brand/recond/new/ballbaring/etc..)
2. Wastegate (with/out/inter/external/down pipe...)
3. Intercooler (using fan?/on all d time?)
4. Injector (replacement/additional/
5. Engine Oil cooler (is any?)
6. Blow-off valve (psssshh... sounds cool)
7. Boost controller (manual/electronic... safety 1'st maa)
8. etc....
9.....
wah everybody doing turbo ya nows day,,hi..hi....well all the i tem u listed all can use it but it is depend on u either u want to have low boost or hight boost,so the item that will be install will be differ a bit maybe u wiil have to use boost controller,or maybe u have to change a few part if u want to play high boost it is depend on u too.well for more details it is depend on how much is ur budget,so i think u better go to the wrkshop the number already give right ,call la the towkeh he is friendly and easy to talk ma..i have been there and u can discus with him wht u want.try la..he wont eat u if u dont want to do it ...come on malaysia bole :ph34r:
8. etc....
9.....
Hi bro ,
ok let list down the details of the turbo kit :
1. Turbine (TD-05H or our hybrid ball bearing turbo) both in recon condition.
2. Both turbine using back original internal wastegate , s/steel custom made downpipe.
3. Intercooler = if you are using front mount intercooler , no need to use fan. if you mount it at the side for hidden , then you need to use fan in ALL THE TIME.
4. Injector = remain the four original injector , additional 2 pcs bigger cc for turbo use.
5. Engine oil cooler = if have it will be must more better , but not easy to find cause we need a adaptor . Even if chop shop have they sell very expensive.
6. Blow-off valve = must have la , just using normal 1 enough already.
7. Boost controller = depends , standard boosting 0.7 - 0.8bar.
8. e-manage = MUST HAVE COMPLETE WIRING , INJECTOR AND IGNITION HARDNESS , OTHER WISE CAN'T HELP !!!!
9. turbo timer and boost meter.
10. 2.5" exhaust
Checked out the car today...
very nicely done.. double thumbs up...
by the way... civicturbo, im the specky guy with little hair and dark green civic.. :P
Bro your also take very good care on your car .... :P
Anyway nice to meet you . :)
Thanks for your list man... i appriciate it. Another questions...
1. Now i wonder bout your boost level. Currently u set it at 0.8 bar (11.76 psi), most of imported turbo kit (from site laa) recommends max 7/8 psi only (approx 0.5 bar) with direct bolt-on. How could u do that? Our D series can tahan ka?
2. For turbo, is good to have less ristriction in ekzos design. currently i install high flow cat for my center bullet and removed original cat, this because mine is auto tranny. Wat do u suggest for turbo + auto tranny?
3. 2.5'' ekzos piping included in your offer? :D
lilvee :
Bro , thanks for asking , hope can help you more on turbo kit ...
1. you are right , normally standard turbo all come with 0.5 bar . But depend on which type of car we are talking , SR20/V6 TT/4G 93 all come with 0.5bar , but evo 1,2,3,4,5,6,7,8 all 1 bar standard boost, anyway i up boost it with electronic boost controller , but without it i also can up boost the turbo . the most importance is the setting for the car , if set it wrong , the engine will still damage even you have EVERYTHINGS inside your engine....
2. what i suggest is just fix 2.5" exhaust from d/pipe to rear muffler , rear muffler must be straight flow , is very good already either auto or manual .
3. :( sorry la bro is not include.....
Originally posted by civicturbo@Feb 23 2005, 09:31
kikikuku :
bro how is your car now ? when free yam cha la....
hi there? ;) civic turbo are u the wrkshop owner?i only know N.D,dunno the full name la,hehe..i go there asking about my car,asking him how to make bolt on waja turbo.bcoz i already met the waja turbo that he set up with bolt on turbo kit,it can boost 0.8 bar without change the block head gasket to lower the compression.it is good engine,hehe..actually he ask me to call him if i want to install the kit,coz i already have a few stuff la for my project,but ....well......the budget is run already (rrruuuuuuuunnnnnnnn aaaaawaaaaaaayyyyyyyy) :blink: :( ....so the project will pospond until enought loo...heheh.... :D B)
Originally posted by civicturbo+Feb 24 2005, 09:13 -->
QUOTE (civicturbo @ Feb 24 2005, 09:13 )
--QuoteBegin-blur_civic
@Feb 23 2005, 16:08
Anyway nice to meet you . :) [/b][/quote]
Nice to meet you too... Hope to see you again soon.. :P
kikikuku..
how was the waja turbo? smooth?
I believe you can discuss with N.D. to use your items for the project mah.. work out a suitable budget for you..
the waja turbo look ok,but the time i meet him is not his free time lor.. bcoz that time he going out to bank(related to his office business)for some thing.so excidently....hi.. i call him and he said can lo if i want to se it we meet at infront mpsj building,i just se what already done with it ,he said that the car when he test 0-100 can get 6-7 second if i am not wrong.so it is good work there.job well done ma...emm maybe la i think alittle bit more day or some some day le,actually i am also study so have to maintain my budget la to pay the fee...so long life turbo or i like to call "Jentera Berhantu"(Haunted Machine) he ....he.....car,women,car,car,modified i love malaysia :P B)
Civicturbo
Thanks man for ur advise. Now, i know wat to do next... surely i'll call u and have a test drive with u... :D and take a look ur hood.. key
Bro kikikuku...
I had accounter 1 very2 fast silver waja at kesas from usj.. its look soo sleeper... I tell you... wow its fast man :D and 1 of d reason why i wan to boost my car... hihihi
Bro akimoto... thanks man, to share ur experiance... ;)
Originally posted by lilvee@Feb 26 2005, 15:44
Civicturbo
Bro kikikuku...
what the plate number?or how it is look like?do the waja have a wierd look? :D
just asking if look kind weird just always se coz i always go to ss 15 thaipan,eh maybe u meet the waja turbo that made by dragger motorsport he is working at that area,but he is in brown one,hihi....turbo...turbo...("jentera berhantu") :unsure: :unsure: :blink: B)
hi,the place at kepong,there is a industrial area there,i dont remember the name but just beside sri damansara,also near to tmn ehsan lo.i dont know la how to say it but if i am not wrong already somebody here tell how to go there try check the posting before k,y u want to upgrade too??
