best torque car
normality78
3,000 RPM
Let's do some survey.
1. Which car got the best torque produce under 1.6cc classification?
2. Which car model got the best torque design inlet manifold?
How to classified? Max torque must be hit before 4000rpm. NO TURBO. ONLY NA
So far to my own reckon is Kelisa 1.0l EJ-DE and Myvi 1.3l K3-VE got the best design inlet manifold
issit the comparison is based on spec? then perhaps we should standardize a rpm of max torque if really want to compare.
you include NA and forced induction? how about diesel? u want specific statistic based on malaysia market cars?
old waja with 4G18 has good torque output characteristics, my 2 cents
hmmm i would agree. i drove a vios and its powerful at low rpm. however, im not good with numbers.
just my 2 cents.
why cant just take the max torque? coz there is no point having max torque at not pratical power band
I assume we are only talking about stock cars, no?
Stock cars have practical torque bands so taking maximum torque is not an issue. We aren't talking about highly tuned machines here, right?
1/10 scale remote control car with a .21 engine and a 3 speed.
On a power to weight ratio sense, awesome. 0 - 100km/h, also awesome.
yup, we r talking about stock car. why not max torque like what i explained earlier on? simple. Car A can develop X amount of torque but at only 6800rpm. Car B can generate lower X amount of torque but it can reach its max Y torque at 3800rpm.
If to compare, no doubt A have higher torque output but at the 3800rpm, it may have much lower torque output thn B.
that's why i only limited till certain rpm coz those r normal power band usage on street
to me, nothing beats sheer capacity power. bigger cc, bigger torque output.
i search wikipedia and
1. Waja 1.6 Campro (S4PH engine) produce 155Nm at 4,000rpm.
2. Toyota Vios 1.5 (1NZ-FE engine) produce 142Nm at 4,200rpm
but i do think Vios is more driveable and feel more power due to VVTI @ flatter torque across rev range
on the other hand, Civic's screaming B16B VTEC from EK9 Type-R produce the most out of its NA 1.6litre engine. 160Nm but happening at a highly 7500rpm.
wonderful horsepower perhaps with 185bhp@8500rpm
how to design a basic engine with good torque characteristics?
1. long strokes @ undersquare engine (oversquare if your want high power output)
2. 2 or 3 valves per cylinder (4 or 5 valves are more to high output)
3. in-line engines. Vee engines is a no-no!!
still, a modern engine like 6A10 1.6 V6 from Mitsubishi is capable of putting out 147Nm @ 4,500rpm.
the best data i can find is from a Citroen 1.6 turbodiesel engine which produced 240Nm. it was used in the ZX, the Xsara and currently the C4 and C4 Picasso
however, this engine is out of threadstarter scope but somehow we can make it a benchmark. any engine below 1600cc able to beat that figure?
