best piggyback for Lancer CS3A 4G18 engine
ronaldinho_375
hye bro-bro MLOC sekalian,
really need ur help..
what is the best ECU piggyback for my lancer CS3A 4G18 engine since Powerzone workshop told me that e-manage blue & afc neo just only can adjust fuel n cant adjust ignition.. not worth it install they tell me.
they suggest for Haltech Platinum Interceptor... complete with tune & dyno RM2900...
its worth it for 4G18 engine that modified only install Powerzone performance extractor, K&N drop in filter, high performance Powerzone cam shaft & adjustable cam pulley to use haltec..
really need ur advise bro-bro MLOC?
i want to increase my HP and torque since my car very very slow maaa with 17" rim.. very menyesal tukar rim... kancil pun bole tapau my lancer kat traffic light.
Hi thr ,
For me what i had done with my CS3 as below:-
* Aluminium Cam Pulley
* Aluminium Crank Pulley ( if able change it all to aluminium to lighten d engine to get back your HP up )
*SARD High pressure Fuel Pump
* Fuel Regulator
*4 2 1 Extractor
*atf cooler ( remember to change ur atf every 20k km)
*Earth wire
** currently looking for racing cam , valve, valve spring and throttle body....
Any better suggest is welcome :biggrin:
Recently, I see the trend of 'bolt on turbo' at the Marketplace, maybe you can try. Paying 2.9K just for the ECU and tuning, I think it's a bit too much. Just my personal opinion.
dude, u mean 4g93 sohc terbalik?? how much would it cost dude???
Yup, try to look for the block of 4G93 SOHC terbalik. very hard to look for it. last time, the cost should be around RM 1.5 k - 2 k (including installation if i'm not mistaken). can upgrade ur engine cc from 1.6 to 1.8 without approval from JPJ.
