Beaks sub frame rear aluminium lower tie bar honda
d&d performance
Beyond 20,000 RPM!
The Beaks Rear Lower Tie Bar is made from 6061-T6 aircraft grade aluminum and brackets. Unlike most aftermarket lower tie bars that use a rod end bearing type connection, the Beaks Lower Tie Bar has no pivot point, and feautre a square tube configuration that provide excellent rigidity which reduce subframe flex under load.
Most aftermarket lower tie-bars use a rod-end bearing type connection for proper fitment. This however allows the subframe to flex under load and minimizes its effectiveness. The Beaks subframe tie-bar design has no pivot points. Its square tube configuration provides excellent rigidity and lightweight.
KEY FEATURES:
- 6061-T6 aircraft grade aluminum tubing and brackets
- Stainless and zinc-plated hardware
- New Color Metallic Gunmetal finish
available color blue/gold/black/silver
- Installation instruction
for honda civic EG EK
installation can be done in
D&D performance s/b
-no.18&20,jalan pjs 11/7,bandar sunway,46150
petaling jaya,selangor,malaysia.
tel:+603-56380888
:+603-56370888.
fax:+603-56316888.
email:[email protected]
hp:+60163328136 seng
:+60162111820 kenny
:+60162173767 frankie
d&d performance
016-3328136
---------- Post added at 10:27 PM ---------- 6 hour anti-bump limit - Previous post was at 05:02 PM ----------
d&d performance
016-3328136 seng
d&d performance
016-3328136
seng
bump bump
---------- Post added at 01:22 PM ---------- 6 hour anti-bump limit - Previous post was at 11:52 AM ----------
d&d performance
016-3328136
seng
bump bump
