bad turbine??
karl_razlie
need to know about turbo condition.
-how to check turbine?
-what sign of bad turbine?
-can bad turbine send to service?
becoz i already buy one turbine, then dunno izzit ok or not and how to check...so hope any sifoos outthere can help...thanxs
Google searched, try this site:
http://wwwrsphysse.anu.edu.au/~amh110/turbo_page.htm
Hope it helps in little ways...
Cheers.
G-18,
Well, that's another good way to describe turbines. This is can be overcome by some aftermarker, tuned anti-lag system ;)
Cheers.
look for freeplay at the wheel (radially and axially). it should not be excessive. check for clearance between the wheel and the housing.
It may help if you gently turn the turbine, and try to feel if there's any obstruction. the wheel should spin freely ....
