hey guyz was plannin 4 a upgrade from my vj20 2 maybe a vf10.any comments???
Originally posted by Khorne@Apr 18 2005, 02:55
Very good upgrade...
Sifu TKK recommends it and I've becone a true believer of it...
Worth the money...
CHEERS
[snapback]905989[/snapback]
Originally posted by bluemaniac323@Apr 19 2005, 14:17
why is the vf8 upgrade better? isn't the vf10 bigger and spools up faster?
[snapback]910293[/snapback]
[snapback]905900[/snapback]
Originally posted by whozeyadaddy@Apr 20 2005, 16:20
the VF8 turbine has got a bigger compressor wheel than the VF10 (only the inducer side) and significantly bigger exhaust wheel...it wont fit directly into the B8 exhaust housing...you gotta exchange the B8 exhaust wheel over but still using the VF8 hub...the VF8 compressor housing wont fit the B8 hub...lots of work...
[snapback]913913[/snapback]
pimpin323 said:then sell me your stock turbine can put on my b6t lolz
keong_GSR said:as for b8 engine,go for B8 210 VJ20 lar...sure power! ;)
iman__210 said:guys,
look at your target...bigger hp doesnt mean fast if u dun tune it right
with proper tuning apparatus and methods.
if u want a reliable and quick spool turbo by all means go for the proven
upgrade..so far i've heard vf10 is a reliable mod..vf8 none heard so far...
but for me fully utilised the vj20 first...coz my target is a daily driver
with both balance accelaration and top speed.
The VF10/BPT doing 240whp is dependent on many mods i.e. engine management, fuelling lines, and what boost.quen said:hi,
i believe VF10 is a cheap and good update for BPT. but for VF8 is the way go for bigger BHP with what you guy looking. i saw a number of VF10/BPT they can do 240whp
VF8 is much bigger compressor fin and turbine fin than VF10. based on the turbo calculation VF8 is can get about 300BHP.
all depends on the money how much you planinig to spend.
