B8 180 TURBO
Levin92
hi all mazda/ford sifus,
jz want to know wat type of external wastegate can be fitted into a B8 180hp model... B)
Thanks n have a nice day...... :D
Anything that's not too big. Space is limited between the exhaust manifold and the radiator. Probably 45mm or so would be a snug fit, and sufficient to flow the waste gasses.
Hi Battousai,
Thank you for the info... B)
wat kind of brand do u think that i should use.....HKS...APEXI...or...MAZDASPEED??? do u know where can i get the cheap product??? B)
Cheers Mike... B)
Originally posted by Battousai@Sep 20 2004, 15:04
Many companies make good wastegates, Trust, HKS, TiAL, Turbosmart etc...
All i can say is performance doesn't come cheap.
Thanks for ur info... :)
Originally posted by laserman@Sep 20 2004, 19:05
levin82,
nice engine, i think wastegate size will better below 40mm... cox u dont need so big for your 180 turbo.
Actually the B8 not mine... :) is one of my best friend... :)
u said the wastegate better below 40mm then the normal wastegate is wat size n the smaller size is how much the size??? Because i really dunno the size of the wastegate is XXmm to XXmm..... :unsure:
I'm using 36mm ext. w/gate, work great so far..... advantage if u have Elec. boost cont. to compensate the lag of an oversize ext. w/gate.
ABie.
ABie.
i will try to find the 36mm ext. wastegate n one unit of boost controler...... :)
then wats the market price of the 36mm ext. wastegate (brand new n aftermarket)???
:D :D :D
Laserman (I know who u are :P ),
I dun wanna go KL liaw lorrrr.... u guys will eat my car for breakfast after this.... hahahahaha. Scared already, must ask for handycap match :P .... all tx3 car now very fast lorrr....
Levin92,
Me from penang lorrrrr.... BTW TiaL ext. w/gate 40mm brand new RM1050.... where Elec. BC price 2nd hand varies from rm400 - 700 depend on brand..... I've got mine (apexi AVCR 2nd gen) for RM650 long time ago.......) still using it.
ABie.
abiey,
TX3 slow lah...compare to urs...maybe except 1 (black colourloh)..u know lah...hopefully the dyno will happen soon too...
Originally posted by abbiey@Sep 22 2004, 10:28
Levin92,
ABie.
ABie,
Thanks for your info... ;)
izzit the 36mm ext. wastegate will cheaper than the 40mm???
how about the difference power of this two size??? :huh:
B) B) B)
Originally posted by laserman@Sep 22 2004, 14:18
abiey,
Laserman,
Ya I know oledy.... the black TX3 already dynoed and produce such WHP with only little boost (not even 1 bar) .... I'm quite impressed! Good setup maybe .... so after this must test on the road condition...... hehehehe maybe KK can give handycap match ka? hahahaha just joking :P
Levin92,
36 mm should be a little cheaper compared to 40mm...... but I think nowaday at market only can easily find 40mm...... they said 36mm is so small...... :angry: power will always be the same only the respond is different but not much if u have Elec. b control.....
ABie.
u buy TiaL ka, HKS ka, Turbosmart ka, brand new less than RM1500 must be imitation la.. hehehe semua siam mari punya..
i also use siam product, Nitto 35mm (ada ke 36mm?? typo error kot?)
Siam product - same performance. reliability depends la..
hari hari hantam boost, after 1 year sure koyak the diaphram..
easy to get replacement maa..
u buy original also same problem, after 1 or 2 years sure koyak.
my nitto can last about 3 year, just replace the diaphram, RM250 only
siam product can get less than RM650 brand new.. u want HKS or Tial?? hehehe
hi brother.... welcome to ford/mazda family... have so long never see you...
so here will have more n more friend.. this forum canot be die..... seen we all are supporting
i can get less than RM500 for thailand wastegate. just let me know... 35mm trust
hmm..sound cheap..izit the brand new product? do you need to mod alot if wanna fix the extenal wastegate? around how much it will cost?. :)
hi,
is brand new product.. is from thailand...
to fit in our manifold you need to modify for sure
