B20 Vtec engine + B18C Type R camshaft
Block: B20b with 84mm stock pistons, stock con rods, crankshaft, alternator and oil sump. Complete block. Just changed timing belt and head gasket. Got receipts to prove.
Head: B16 complete vtec head, just overhauled, Got receipts to prove. Comes with standard intake manifold and 4-2-1 header. Please take note, no distributor and no wiring.
Extra!! B18c Type R camshafts+valve springs+cam gears. Just plug and play into B16 head. You can still keep the existing b16a camshafts+valves springs!
Selling all as a set. Dyno tune up to 200hp with B18c Type R cams.
Plug and play into Honda eg/ek.
For D series conversion to this setup, please do your own research. Information is everywhere in Google. I will only share with you the service records of this engine to prove that it is in good condition.
For existing B16 user, good upgrade, just plug and play!
Interested please Whatsapp +6598775697 or Call +60167962486
Read more at http://www.mudah.my/B20+Vtec+engine+B18C+Type+R+camshaft-38761716.htm#yUAGVxghH899fBfi.99
