B18C or B20B
zero4 said:
HAHAAHAHAHAHHAHAHAHAHAHAHAHAHAHAAHAHAHH
sepat, he answer yes somemore
the way he put th word after the full stop without space before starting with new sentences reminds me the same way ah tiong did last time.. ngeh ngeh ngeh
little_monster said:
option 1 did b4 but not using type-r crank or con rod just B16B 81.25 piston ... the rest all B18C stuff with B16A head and toda cam managed to get 166 whp and torque is around 18.9
option 2 the specs sounds great but the block not done in a proper way the engine would not last
lemme guess little monster..
u aint on any of the above categories.. so i assumed that more than 220 ponnies now sittin in your engine bay ngeh ngeh ngeh
Thanks for all your guys feedbacks.
It seems like alot more need to be done to get a B20B revving high... Hmm.. But we always hear in US guys running 2L and all revving 10k rpm.. If I built a economical B20 and cannot rev above 8500rpm (though most things happen below that due to the torque), I think really no fun le.. Considering Honda Vtec are design to rev high..
So if I go Option 1, will B16B pistons yield too high compression causing detotanation and also make it not reliable? What about valve to piston clearance, do you think its going to be difficult for the mechanic to set??
As for ECU, I know Microtech and Hondata is good, but from my experience, it is how good the tuner is rather than the product. I can't seem to find one ECU tuner i really confident with tuning fully programmable ECU.
Like Hondata I was actually pretty interested in the S300, but just don't know who can tune them properly.
Still confused..
it is obvious yoooo
Still confused..
there is one good tuner for hondata here, but sadly, i cant remember the name, i will post here once i get his name. microtech you can always look for joshua, so far, he is famous for tuning microtechs
hahahaha... yah yah i am driving a 2L ... but onli 150bhp on flywheel.... ekekke i guess tats good enough for a stock CRV hahaha
zero4 said:
in your case, better opt for:
Option 1
B18CR Block + B16B Pistons + Toda C / Jun Type 3 cams and valvetrain
Rechipped ECU tuned via Greddy Emanage
Everything else stock B18CR
Concerns here is that some said the Compression ratio will be damn high like 13:1 so won't last, some said if Toda C used then ok cause static CR drop. Very Confused.
drop in a microtech LT-10s if u can
what is the estimated atw hp for this setup? n the b20 as well...
Thanks to all sifus here.
After very much consideration and current budget constraint, I will go for Option 1.
It will be:-
B18CR engine + B16B Pistons + Toda C Camshaft + all necessary parts + Re-Chipped ECU
I will be using my old Greddy E-manage taken out from my previous car and use it in this project to fine tune it. Really hope to go Microtech or Hondata but thought better save the money and buy only when I have enough budget to do a B20 next year.
Will be sending my car to my mechanic this month end. Wonder how much ponnies I can get out of this setup and how long it can last.
Also anyone know who can tune a Greddy E-Manage properly in KL? My mech told me there is someone who comes up from JB to tune cars and had been pretty good so far with his customer's cars.
WalBro(Apexi) said:
vrooooooooommmmmmmmmmm!!!!PLAaaaaaaaaaaaaaaaa
Hi Walbro
Your RM products does really look good. But currently budget constraint. My mechanic willing to lend me the Toda C and springs for this project.
Anyway the RM M24x and M25 seems pretty high.. Will it deliver more power than Jun 3? I have used Jun 3 on stock engines before and power is very nice with stock compression. What would the price be including springs+retainer?
Also can buy just retainer+springs only? Price?
Just want to know so next time can budget myself.
Thanks.
It will be:-
just my 2 cent with this setup B18CR engine + B16B Pistons + Toda C Camshaft + all necessary parts + Re-Chipped ECU u might hit 185-190 ++ whp but it all will depands on your mehanic skill in assembling the engine and tune the e-managed....
acheivable ler, chris2000 drop in a good gear ratio also ler
Little Monster,
The problem with mech is he is only good at mechanical mod like engine assembly, cam setting etc but he can't do electrical tuning like ecu. Cause during is olden ATCC days all this programmable ecu or piggyback was not allowed, henced he never got around learning it. That is why he ask me to get a ecu tuner myself to maximise power and relaibility.
Zero4,
Hope can achieve good reliable power. I already running ATS 1-5 gear with 4.4FD.
i don't know why some of my friends like to use Toda C...
for me...might as well i use typr-r cam...as of the price for toda-c
might as well i get Jun-3....because why,the power from toda-c
not as power as i thought...same opinion as my 'pomen'
just my 2 cents....no flame...
mugen 9 u aren't flaming, a lot of ppl say the same too, why toda, just use type r camsloh, for that price, get jun 3. but then again, different cams benefit different setup, maybe a toda c will help a b20b more compare to jun 3. hard to say one sometimes.
We need to do some comparison between ctr cam/jun3/crower3/todaC ........... hehh hehhhh then we can differentiate it....let's start with zero4 and mugen9.....
