b18c gearbox s80
lwk2047
hi to all sifu.i noob meed u guy help.i am using s80 2027073 b18c gearbox.some question here.1. wat is the fd in this gearbox?2.wat i have to change to make it more pickup n high end.all sifu pls help thanks :adore:
if u took this gbox from a dc2r yr 98+..i suppose u should have a fd 4.785...it should bear the 'N3E' on the gbox casing..to confirm try to check ur speedo at 5th gear@rpm 3k..what is ur speed?:driver:
as for no.2..lets hear from other sifus here :burnout:
want pickup and the same time at high end?
heee..it's vice versa..so, the choice is yours..
want pick up..loose top end..and vice versa
os 4.643 is for high or wat i am noob la haha.then how about gear12345?how much is the os 4.643 fd?
Bump: how much is the os 4.643 fd used la haha.then it is good for pick up or high end?so how about gear 12345
although u had the itr gb.. the ratio are all the same as b16....
so to make some pick up n high end a lil bit... plonk this 4.6fd rather than 4.7....
otherwise u get integra gsr 4th n 5th gear + 4.7fd.... baru kaw.....
my gb is itr ka?i think is jz normal integra gsr gb lo.then if mean jz change 4.7fd is very good already lo bro....thanks for ur info bro.:itsme:
