B16a
kev1234
i got a eg6 b16a and its auto ...
if i wan to change to manual which part i should change?
gearbox..
ecu and wiring wan to change??
is there any problem?
thank you
Originally posted by Riezal-R@Apr 7 2005, 17:19
I think ECU and gearbox. Minor wiring work if you want to use chipped ECU.
[snapback]876797[/snapback]​
is there any problem??
ecu can ar..??
ecu can ar..??
[snapback]876822[/snapback]​
[/quote]
what problem? ECU can wat? Say properly la.
Originally posted by spoonDX+Apr 7 2005, 22:36 -->
QUOTE(spoonDX @ Apr 7 2005, 22:36 )
--QuoteBegin-kev1234
@Apr 7 2005, 18:18
bump
[snapback]876976[/snapback]​
Done with g.box n ecu, you should change cam to manual cam.[/b][/quote]
no need. till now there is no proof that automatic and manual cams are different.
i did auto to manual conversion before, but on b16a 1st gen DA8.
u need :
- manual gearbox
- flywheel, clutch set, hydraulic clutch pump
- complete set shifter and gearknob
- ecu re-chipped
- some re-wiring (remove unneeded one)
- manual pedal set
Originally posted by soulfly+Apr 8 2005, 00:19 -->
QUOTE(soulfly @ Apr 8 2005, 00:19 )
@Apr 7 2005, 18:18
bump
u need :
- manual gearbox
- ecu re-chipped
- manual pedal set
[snapback]877888[/snapback]​
[/b][/quote]
thanks soulfly...
thanks everybody..
and when its already convert..did the hp same as ori manual??
:D :D
@Apr 7 2005, 18:18
bump
u need :
- manual gearbox
- ecu re-chipped
- manual pedal set
[/b][/quote]
thankssss again...
coz i really need this info..
next time i belanja yam cha
Originally posted by kev1234@Apr 8 2005, 08:06
thanks soulfly...
thanks everybody..
as for me, the difference is hard to be noticed bcoz using re-chipped ecu :P
unless using original manual ecu, then can compare whether the hp is the same or not.
Originally posted by soulfly+Apr 8 2005, 15:08 -->
QUOTE(soulfly @ Apr 8 2005, 15:08 )
https://www.zerotohundred.com/forums/style_emoticons/default/tongue.gif alt='tongue.gif' />
[snapback]879370[/snapback]​
[/b]
thanks again soulfly ..
and does the engine use many petro?? :lol:
