hattech-v said:buy storm.
CIVIC68 said:What you guys think about B18C GSR (non Type R) compare to B16A on perfomance & also on getting after market parts ?? example: can a Type R cam & valve spring & other B16A common parts be fitted into a GSR engine?
399 said:Specifications Honda Civic Type
Engine: Transverse 1595 cc DOHC 16V VTEC four
Bore/sroke, mm: 81.0/77.4
Compression ratio: 10.8 to one
Power185bhp at 8200rpm
Torque: 117lb ft at 7500rpm
Power to weight ratio:167bhp per tone
Transmission: Five speed manual LSD, 4.785 final drive
speed: 125mph
0-60 mph: 5.7 sec
final drive is4.4, max speed is 135mph, 0-60 is sub 6s (u can never dip below 6 for stock).
avantasia said:ABANG,
btw can i overloan the car i'm buying to fund for my conversion?
if u wanna buy the ctr halfcut it will cost u around 10k to 13k...for Ek or EJ the maximum loan is only 4+k ...so u cannot expected full loan or higher loan from finance recently....so u figure it out okie....
