automatic gearbox need replace clutch/torque convertor?
Northiswara
2,000 RPM
to sifu and expert,
i wonder if we need to change the clutch plate or torque convertor in the AT GB?
for manual GB we need to change the clutch plate when there is less grip so how about for auto gb?
when ur car is lossing the torque, normaly is time to check ur GB oil or overhaul it.
clutch disc n o-ring/oil seal hv to be replace during it. torque converter is not necessary if its in good condition.
but when u sent to workshop for quotation, normally they will ask u change torque converter, circuit board/valve body,overhaul kit, flush.so to get higher profit.
wat i know is torque converter n valve body/circuit board not necessary to change if it stil in working/good condition. just overhaul it then ok.
my2cent
so there its a clutch plate inside auto gearbox. thanks bro.
never heard ppl change clutch plat in auto gb.
can i install semi racing clutch plat for my auto gearbox bro??
sounds crazy but want better performance marr..
guess u nvr seen auto GB clutch disc before.its not like manual trans only got one, in auto gb..there hv many clutch discs
yes i hvnt seen any auto gb.
then if change all the clutch plate for auto gb sure bankrupt lorr.
CVT got how many clutch inside?
depends on what car u drive. If mitsu / proton, thn you're in luck. There is a shop in KL does have performance rebuilt kit.
Hey, sorry for bringing up a 6 year old thread.
But this suddenly came to my mind. And I Googled.
To here.
So my question is if i occasionally rev my engine to 5k +/-,
how long only do I need to change the clutch?
And how do i know that I need to? @.@
To here.
When your car feels sluggish and powerless until you rev it cukup cukup. Otherwise don't bother
