Atos Perfomance
go make complaint ATOZ not good .. hahahhahahahahaha .. just say a salesman as me to do sooooo .. hahahahhahahaha ..
munir jual namee tak dapat komisen .. camne nie .. :(
munir said:
oit meastro...jual my name ka hehehehe it's ok bro thanks...
mike...haiya it's already ok or not..
mataoo...still under warranty or what...if still...go back to any hyundai service centre and made a complaint
munir..now my atos got problem again la...when sit inside you can hear big big noise.i check already not suspension problem but donno that noise come from where?pls give tips.......
my fren ask me to install surbo in my atos since he has installed in his gen-2..quit good FC and of course more pick up..
mieliki said:
I'm riding on a ATOS 1.0A..
As for going uphill.. can't really say much as everybody knows that it does suck big time!
For straight road & downhill.. I'm 0 to 100 at about below 18 secs.. Best configuration that I manage then is as per below:
-Iridium Platinium Spark Plugs
-The Outlaw Octane Boosters
-Shell V-Power
- Everything else ori.
Feel free to provide me with any advice on how I can better the performance.
I'm also looking at options to modify the Air-Intake as well as maybe either NOX or turbo charge.
surbo .. don't waste your money but still if you want to install .. it your money .. your fren Gen2 install .. not enuf power meh .. haiyooo Gen@ already so KUAT wooo and FC very safe ..
well my advice .. no need to install those thing . you won't regret now buat later .. but stil if you want to install it .. your money ..
cheer mate ..
i read the manual mention that we should drive with O/D on to more fuel economic?is it correct??because when i bought my atos,the salesman said i must off the O/D on on when i need to overtake...
anyone have idea....thanks..
mike...u r already modi on air intake and might be touching to the bonnet...better check again lor
fahmi....for me lar better dont waste yr money to this surbo system....
overdrive hhmm im also donno but its depend from yr driving style lo...overtake and to get more pick up is correct but using OD time cruising which mean u r using third gear only and not forth...its can save fuel
hi...i'm newbie here...currently driving atos...but feel bad i driving manual...if not i got OD... haha...just bought 5 years ago....any modification i can try? i just put a RPM meter but the meter not really show the right thing cos it touch 500rpm...i taught normally car can do 980 rpm??? can any sifu teach? cos DIY myself...nice to meet u all
hi skyrap...for me manual version its much better if based for fuel comsuption...
about rpm meter...haiyo install from accessories shop not accurate...
where's titanrev?
he used to do up his atos.. quite impressive..
ask him the hp figures he got from the dyno test..
u'll be shocked.. well at least i am..hehehe...
[no larr munir...the air intake i modify long time already wat..that time go find you you also see wat....never touch my bonnet la...and for the O/D i really donno why la...it really will change gear la...when i set o/d on reach 160km then auto change to soft gear i think is 5th gear la...cox from the 1st day i take my atos i count my gear when gear box changing gear.and 1 more atos got speed cut 1 or not?why my 1 can go till 175km de?really scare.i mean i scare my gear box PECAH later...my buddy tell me only can reach 160km only....why mine 1 got alot porblem 1?using L2(gear box) when reach 95km change to 3th gear..then use O/D till 160km also change gear..i mean if want change don untill 160 ma 140km already can change later gear box boom la...and did hear about new HYUNDAI ACCENT SR?2000cc got turbo and 200HP...izzit really?malaysia out liao ma?what's the price?i want trade in..you there can do for me?
Hmm.. Are there still many Atoz drivers out there?
Maybe we can get a list of us or something.. then form a group of our own?
my atos. ecu re-tuned at SC, changed filter and exhaust system(S-flow) and piping... some other gadgets... topspeed can reached 180kmph (shown at meter but when compared wif fren's toyota SEG meter shown oli at 160km/h), fc about rm35 go for 360km. pickup just improve a bit ... for me its quite satisfied lor...
which SC did you do that .. how much did you spend .. ???
ecu re-tuned at glenmarie...exhaust system at cheras...actually mine is 1st batch 1 liter inokom atos ....since ever ppl keep on complaining the FC then they've recalled all the atos to re-map the ECU after tat the FC really improve a lot and performance also better but the engine got pinging sound. i think they hv advanced the ignition timing, it's FOC. for the exhaust i spend about rm 1000.
