ATF 12.5L Fluid Refilling Set With Adaptor
Car Culture
jaspersoong
- Used for filling fluid in ATF, Gear oil, Differentials and Transfer Cases
- Additional openable cap allows you easy to refill or empty the tank
- Included 10 adapters and one hose with super flexible rubber nozzle
- Applications: Audi/VW, BMW, Ford, Honda/Acura, Mercedes-Benz, Nissan, Toyota/Lexus and Volvo ATF.
- 5Ft Universal PVC filling hose with a quick coupling that can be connected with filling adapters, this hose also with flow control and safe auto shutoff valve as well.
Temperature range: -46c° to 80c°
1500mm-long ROHS PVC filling hose with a quick coupling that can be connected with ATF refill adapters
Manual operation: the exiting volume of fluid is 0.1 litre per manual pump
Pneumatic operation: the exit volume of the fluid is 0.18-0.2 litre per second
