Body
- Two door coupe or convertible body style with 2+2 seating
- Extruded aluminium bonded body structure
- Aluminium and composite body panels
- Extruded aluminium door side impact beams
- Xenon gas discharge projector headlights (dipped beam), halogen projector headlights (main beam) with power wash
- Power fold mirrors
- LED rear lights
Engine
- All alloy, quad overhead camshaft, 48-valve, 5935cc 60° V12
- Mid-front mounted, rear wheel drive
- Engine management system with Neural Net misfire detection system
- Fully catalysed stainless steel exhaust system with active by-pass valves
- Compression ratio 10.3:1
- Maximum power 335 kW (450 bhp) at 6000 rpm
- Maximum torque 570 Nm (420 lb ft) at 5000 rpm
- Acceleration (Coupe manual) 0-60 mph in 4.7 seconds 0-100 km/h in 4.9 seconds
- Acceleration (Coupe automatic) 0-60 mph in 4.9 seconds 0-100 km/h in 5.1 seconds
- Maximum speed 186 mph (300 km/h)
Transmission
- Rear mid-mounted 'Touchtronic 2' six-speed gearbox with electronic shift-by-wire control system
- Rear mid-mounted six-speed manual gearbox
- Limited slip differential
- Final drive ratio 3.07:1 (auto) 3.54:1 (manual)
Steering
- Rack and pinion, Servotronic speed-sensitive power-assisted steering, 3.0 turns lock to lock Column tilt and reach adjustment
Suspension
- Front: Independent double aluminium wishbones incorporating anti-dive geometry, coil over aluminium monotube dampers and anti-roll bar
- Rear: Independent double aluminium wishbones incorporating longitudinal control arms, coil over aluminium monotube dampers and anti-roll bar.
for more info go to http://www.astonmartin.com/thecars/db9
for more personal info pls call
rick
0124178555
- LED rear lights
Engine
Transmission
Steering
Suspension
rick
0124178555
