ASR Ceramic Coating
is it apline speed racing at sunway...
the ceramic coating is good stuff, reduce bornet heat by 50% and retain heat inside the exhaust pipe... increase 2 to 3 hp.... we also provide same coating,
my 1 is double layer coating.
does it really reduce heat a lot? my engine bay always very hot cos not vented. Ori perdana bonnet. Everytime i opn also very hot inside.
yes it is..... it reduce 50% heat from exhaust manifold.
engine bay still got radiator fan... this fan can produce heat also...
unless use air pump suck the radiator heat from side and release the radiator heat to the side mudguard. then ! would said true 50% reduce under bornet temp[...
not much help , i vented my bornet with Evo3 scope 2. it just look nice but really does not help much, the heat come from turbo exh and fan. the only way is did what i suggest b4...
yes.. almost 0 friction, also can coat on the cylinder block wall..
conrod&crankshaft bearing, caliber piston, valve guide, valve spring, valve, intake port and exh port,,, all part can coat... with diff coating.
