Arospeed Radiator Cap
PandaMotorSport
1,500 RPM
Price : CALL FOR BEST PRICE
Description:
AROSPEED high-pressure radiator caps are OEM style caps that directly replace the
factory cap. Higher pressures inside of the cooling system helps the coolant flow better and also increases the coolant's heat absorbing qualities. Arospeed Radiator Caps have pressure capacities of 1.3 x 100kpa (1.3kg/cm2), in comparison to a factory cap that has a pressure rating of only 0.9kg/cm2. This means that the coolants boiling point can be
raised by using the Arospeed Racing Radiator cap. Advantages are of course found on demanding conditions such as circuit racing.
Available for:
  • Mugen
  • Ralliart
  • STI
  • Nismo
  • TRD
  • Mazda
**Please check the photos and let us know if yours is Type-1(Big End) or Type-2(Small End).**
For more info pls contact Panda Motorsport at:
Office: 603-56117172
HP: 019-2931222
Email: [email protected]
Our Address:
1st Floor, No.30, Jalan PJS 11/14,
Bandar Sunway 46150
Selangor
https://www.zerotohundred.com/forums/attachments/483264.vB
https://www.zerotohundred.com/forums/attachments/483265.vB
https://www.zerotohundred.com/forums/attachments/483266.vB
https://www.zerotohundred.com/forums/attachments/483267.vB
https://www.zerotohundred.com/forums/attachments/483268.vB
https://www.zerotohundred.com/forums/attachments/483269.vB
https://www.zerotohundred.com/forums/attachments/483270.vB
https://www.zerotohundred.com/forums/attachments/483271.vB
https://www.zerotohundred.com/forums/attachments/483272.vB
https://www.zerotohundred.com/forums/attachments/483273.vB
