Ar70 turbo gt35 new
Ar70 turbo gt35 new
d&d performance
Beyond 20,000 RPM!
GT35 GT3582 PRO TURBOCHARGER
* BRAND NEW
* AVAILABLE AR50 / AR70 TURBO
ALL SORTS OF APPLICATIONS
Oil cooled cavity for longer life expectancy and reduced oil cooking.
Huge T4 .70 ar compressor housing for excellent high hp applications.
Large single scroll T3 turbine with 59mm x 45mm inlet opening .70ar for fast turbo response and low back pressure.
Shaft bronze bushing used for fast turbo spool & low friction.
Dual cartridge center section for faster turbo response and higher spool efficiency.
High performance bronze thrust collar bearing used for low friction.
High performance cromoly oil ring's used for long life expectancy.
Light weight ductile casting only weighs 15.80lb for reduced manifold strain.
Compressor Spec:
T4 .70ar housing
4" Inlet
2.5" Outlet 5 BOLT
Big shaft T4 compressor wheel
61.37mm 2.416" minor
81.96mm 3.227" major
Coolant cavity thread 14x1.5 banjo bolt style
Turbine Spec:
.70 ar
Large mouth t3 opening 59mmx45mm
75.32mm 2.965" turbine housing outlet
High flow tapper 4 bolt outlet with 99.60mm 3.921" spacing
Big shaft GT35 Turbine shaft
62.26mm 2.451" minor
67.78mm 2.668" major
Quick Spooling with Longer Turbo life can be use on smaller engine and will decrease lag and make fast response.
Universal application. Additional parts will be needed to complete install. Please consult professional turbo installer for details
D&D performance s/b
-no.18&20,jalan pjs 11/7,bandar sunway,46150
petaling jaya,selangor,malaysia.
tel:+603-56380888
:+603-56370888.
fax:+603-56316888.
email:[email protected]
hp:+60163328136 seng
:+60162111820 kenny
:+60162173767 frankie
installation can be done in
D&D performance s/b
tel:+603-56380888
+603-56370888.
fax:+603-56316888.
+60162111820 kenny
D&D performance s/b
tel:+603-56380888
+603-56370888.
fax:+603-56316888.
+60162111820 kenny
-any enquiry please call or email
d&d performance
016-3328136
seng
bump bump
---------- Post added at 02:58 PM ---------- 6 hour anti-bump limit - Previous post was at 02:45 PM ----------
d&d performance
016-3328136
seng
bump bump
