Hi,
Wonder if anyone had tried various ecu set-up's for RB26DETT. Has anyone tried and tested in the Apexi d-jetro, and what was the results?
And also stand-alone ecu's such as Motec, Autronics, Haltech etc and how these ecu tend to require a module for tps out for the attesa as the oem ecu is calibrated for a fixed voltage of 0-3.5 V for attesa tps signal. I even read, some tuner (in AU) had managed to run piggy-back Autronic set-ups to minimize issue with the a/c, idling, 4wd etc. Any thoughts or experience?
Cheers.
Cheers.
