Anti Rust Device for sale CHEAP !!!!
ah-singh
heya guys i have a few units of "rust evader" designed for our old and rusty,new and shiny cars !...its a device which controls rusting...its ideal for any car.......just need to be connected to your cars battery and its in operation.....on the market , its price can fetch up to rm700!!!......but now its being sold for only rm300!!.....for info , call singh (0177061990).......its a good buy !!!! y not spend money on somethin tat really does work rite ??
Rust is a natural result of our environment. Your car will be exposed to environmental conditions which accelerates the rusting process. Even the most careful use of your vehicle does not prevent corrosion on the autobody of your car. While these damages may not be visible to the naked eye, you may find rust eating away at your car. Don’t delay ! Protect your car, truck or van 24 hours a day – rain or shine – with the world leader in electronic automotive rust control !
The Rust Evader® system retards rust and corrosion so that common nicks, scratches and abrasions won’t deteriorate into rust-through damage from the outside-in or from the inside-out. The Rust Evader® system safeguards your investment and helps to preserve the environment !
* Helps increase your car’s value at trade-in time
* Protection against rust-through damage as a result of stone chips,
nicks, abrasions & sea spray
* Is transferable to your next car
* Original USA technology
* No messy chemicals, environment friendly
* Easy installation
* Over 15 years consumer satisfaction
* Nearly 1.7 million installed worldwide
The Rust Evader® is not another form of chemical rust proofing, but a tangible device – which is fitted much like an alarm. The unit consists of a black command module and two anodes which are non-sacrificial. Unlike the chemical application which "may" protect approximately 30% of your car and only what is termed "inside-out" protection i.e. where it is sprayed, by contrast the Rust Evader® reaches some 95% of your car i.e., the whole shell, the doors, the bonnet, the roof - every seam, seal, and weld of your vehicle is protected not only from the inside but also from the outside where your vehicle is most exposed to the very elements that cause corrosion.
The Rust Evader® module attaches to your regular car battery and draws about as much current as your cars clock. Over every 8 second cycle it emits a surge of "free" electrons throughout your vehicle to the very places your car has lost its protective paint and coatings (through stone chips, scratches, and abrasions) and "shields" these exposed areas from harm. The charge is too small to be noticed, however the free electrons interfere with the rusting process and retard rust and corrosion significantly.
No. Not all automotive electronic corrosion control systems work! The revolutionary Rust Evader® technology is one of a kind and substantially extends autobody life through “capacitive discharge oxidation interference” (CDOI), a form of impressed current technology. The patented CDOI technology is not “cathodic protection” – which has been scientifically proven ineffective in exhaustive laboratory and field testing worldwide. Cathodic protection is limited in application to environments which provide a continuous electrolytic (electrolyte) between the corroding metal (cathode) and the oxidizing agent (anode). When purchasing an electronic corrosion system make sure it is the trade-marked Rust Evader® brand for complete peace of mind.
Application is difficult, and many corrosion vulnerable areas of a vehicle cannot be reached by even the most sophisticated spraying equipment. What’s more in as little as 21/2 to 4 years, coated vehicles have shown extensive corrosion beneath the protective coating. Electrolytes can penetrate the protective coating by osmosis and attack the metal beneath. The coating will actually flake off the metal. This is why the Rust Evader® can serve as an effective back-up to even to most respected undercoating systems.
New vehicle Owners – Get protection from day one to preserve your investment.
Older Vehicle Owners – Prolong the appearance of your vehicle in order to receive better trade-in value
[/img]
more info is good. then at least we know what we're looking at
Ambayah, that's what I was thinking.. mabbe it secretes a substance on the whole car and acts like a giant condom to protect it from external forces! :D :D :D
Well,
I think it has something to do with the electrical properties (ions etc.) that prevents the Iron (Fe) from oxidising with oxygen (02) to create rust (Fe02).
Cheers,
Danny
huh ? .. unrust? Once it's rust. it's rust. Can only stop / prevent further rusting.
Cheers,
Danny
krazz77 said:
Well,
Cheers,
Danny
danny , u are right ! the electrical properties prevents oxygen to be formed between the paint and the body of the car...please take note tat it PREVENTS rust .....so any takers ??? got a few wit me..... :tee:
just want to know whether it affects the life span of the battery or not.. this device definitely sounds logical but just worried bout the battery..
Doink said:
if can prove that car will not rust...after using it...i will buy...
Doink ,come to jb n i will show u my frens toyota ke30....has
been usin tis item for a year....zero rust....
DR 78 , it doesnt effect the battery as it consumes only a
little current.....i have customers usin tis item for
years without any problems to tha battery.....
is this items big size? how does it looks like?
kieranchng said:
bro....how to install if i'm in KL?
bro veli easy to install.....connect one to the positive terminal of ya battery n one to the negative....stick the other two devices to ya car body......can pos laju to u la....
mazda626....waitla...no time la to take pic......
I believe these things work. Few years back they were retailing for almost RM1000, and can only be purchased in USA. There were some people selling it at lelong for almost RM500 last year and RM399 early this year. At RM150, i would probably get it for my car. Its just too affordable. Until something like RM99 comes about that is. hehehe.
But i do appreciate pictures of the product. BTW are you in KL?
