Another new Airtek turbo owner
Good Day to all,
Dean from uk
I purchased a modified Airtrex today and boy does it move!!
On my journey back it jerked a couple times when I planted my foot so it could be that its not the finished article just yet.
Its riding on 19" rims with a 225/40 stretch tyre.
My plans are to take it too a well sought tuner and get them to run the rule over the whole car. Stick it on the rolling road to find out what issue caused the jerking and power output.
I'm sure it can be improved and I'm willing to throw a little money on it!
On boost you hear the clicking noise quite loud so need to relocate if possible or change bc for a better one?
First on my list is to put a hks silent power on it then change the wheels,
Steering wheel, source recaros and brembos then see where to go from there.
Please advise best tire/wheel size combo from 18" to "20 (for instance I was looking at 20x10 56 offset on 5x112 Mercedes amg ml alloys)
List of known mods
Air intake
Twin central exhaust
Boost controller - 2 stage set at 0.6 & 1.4
Uprated Fmic
Turbo
Evoscan software
cams & injectors
Hopefully the fuel pump has been changed!!
Pictures to follow soon
When you plant your foot down and it jerks at high boost, it could be bad MAF sensor. Does the boost swings up and down when it jerks? I had the same issue before my MAF sensor failed. MAF sensor typically lasts 4-5 years.
i would recommend a 18" x 8 to 9 wide, get a 225 to 245 wide tyre with 45 series thick.
what turbo are you running on?
